[PATCH v4 2/5] cpukit/aarch64: Add exception extensions support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Oct 28 21:12:00 UTC 2021
This adds the function implementations necessary to add exception
extensions support to AArch64.
.../cpu/aarch64/aarch64-exception-default.S | 131 +++++---------
.../cpu/aarch64/aarch64-exception-default.c | 59 ++++++-
.../cpu/aarch64/aarch64-exception-interrupt.S | 165 ++++++++++++++++++
.../cpu/aarch64/include/rtems/score/cpu.h | 21 +++
spec/build/cpukit/optexceptionextensions.yml | 1 +
5 files changed, 293 insertions(+), 84 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 2a4ddbcc61..c7c9d03465 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -72,7 +72,7 @@
* * The exception returns to the previous execution state
- .macro JUMP_HANDLER_SHORT
+ .macro JUMP_HANDLER
/* Mask to use in BIC, lower 7 bits */
mov x0, #0x7f
/* LR contains PC, mask off to the base of the current vector */
@@ -109,10 +109,6 @@
nop
nop
nop
- .endm
- JUMP_HANDLER_SHORT
nop
.endm
@@ -144,11 +140,48 @@ Vector_table_el3:
* using SP0.
curr_el_sp0_sync:
- stp x0, lr, [sp, #-0x10]! /* Push x0,lr on to the stack */
- bl curr_el_sp0_sync_get_pc /* Get current execution address */
-curr_el_sp0_sync_get_pc: /* The current PC is now in LR */
- JUMP_HANDLER
- JUMP_TARGET_SP0
+ sub sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE /* reserve space for CEF */
+ str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET] /* shove lr into CEF */
+ bl .push_exception_context_start /* bl to CEF store routine */
+/* Save original sp in x0 for .push_exception_context_finish */
+ add x0, sp, #AARCH64_EXCEPTION_FRAME_SIZE /* save original sp */
+/* Push the remainder of the context */
+ bl .push_exception_context_finish
+/* get jump target and branch/link */
+ bl curr_el_sp0_sync_get_pc /* Get current execution address */
+curr_el_sp0_sync_get_pc: /* The current PC is now in LR */
+ mov x0, #0x7f /* Mask to use in BIC, lower 7 bits */
+ bic x0, lr, x0 /* Mask LR to base of current vector */
+ ldr x1, [x0, #0x78] /* Load target from last word in vector */
+ and lr, lr, #0x780 /* Mask off bits for vector number */
+ lsr lr, lr, #7 /* Shift the vector bits down */
+/* Store the vector */
+ str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET]
+ mov x0, sp
+ blr x1
+ b twiddle
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+ nop
+/* Takes up the space of 2 instructions */
+#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
+ .word _AArch64_Exception_default
+ .word 0x0
+#else
+ .dword _AArch64_Exception_default
+#endif
.balign 0x80
/* The exception handler for IRQ exceptions from the current EL using SP0. */
curr_el_sp0_irq:
@@ -204,13 +237,11 @@ curr_el_spx_sync_get_pc: /* The current PC is now in LR */
mov x0, sp
blr x1
-/* bl to CEF restore routine (doesn't restore lr) */
- bl .pop_exception_context
- ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET] /* get lr from CEF */
-/* drop space reserved for CEF and clear exclusive */
- add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
- msr spsel, #1 /* switch to thread stack */
- eret /* exception return */
+ b twiddle
+ nop
+ nop
+ nop
+ nop
nop
nop
nop
@@ -475,69 +506,3 @@ twiddle:
stp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
/* Done, return to exception handler */
ret
- * Apply the exception frame to the current register status, SP points to the EF
-.pop_exception_context:
-/* Pop daif and spsr */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
-/* Restore daif and spsr */
- msr DAIF, x2
- msr SPSR_EL1, x3
-/* Pop FAR and ESR */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
-/* Restore ESR and FAR */
- msr ESR_EL1, x2
- msr FAR_EL1, x3
-/* Pop fpcr and fpsr */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
-/* Restore fpcr and fpsr */
- msr FPSR, x2
- msr FPCR, x3
-/* Pop VFP registers */
- ldp q0, q1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
- ldp q2, q3, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
- ldp q4, q5, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
- ldp q6, q7, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
- ldp q8, q9, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
- ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
- ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
- ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
- ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
- ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
- ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
- ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
- ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
- ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
- ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
- ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
-/* Pop x0-x29(fp) */
- ldp x2, x3, [sp, #0x10]
- ldp x4, x5, [sp, #0x20]
- ldp x6, x7, [sp, #0x30]
- ldp x8, x9, [sp, #0x40]
- ldp x10, x11, [sp, #0x50]
- ldp x12, x13, [sp, #0x60]
- ldp x14, x15, [sp, #0x70]
- ldp x16, x17, [sp, #0x80]
- ldp x18, x19, [sp, #0x90]
- ldp x20, x21, [sp, #0xa0]
- ldp x22, x23, [sp, #0xb0]
- ldp x24, x25, [sp, #0xc0]
- ldp x26, x27, [sp, #0xd0]
- ldp x28, x29, [sp, #0xe0]
-/* Pop sp and ELR */
- ldp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
-/* Restore thread SP */
- msr spsel, #1
- mov sp, x0
- msr spsel, #0
-/* Restore exception LR */
- msr ELR_EL1, x1
- ldp x0, x1, [sp, #0x00]
-/* We must clear reservations to ensure consistency with atomic operations */
- clrex
- ret
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index 2ebb3dee9f..3494c88ea6 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -41,10 +41,67 @@
#include "config.h"
#endif
-#include <rtems/score/cpu.h>
#include <rtems/fatal.h>
+#include <rtems/score/aarch64-system-registers.h>
+#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
void _AArch64_Exception_default( CPU_Exception_frame *frame )
rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
+void _CPU_Exception_disable_thread_dispatch( void )
+ Per_CPU_Control *cpu_self = _Per_CPU_Get();
+ /* Increment interrupt nest and thread dispatch disable level */
+ ++cpu_self->thread_dispatch_disable_level;
+ ++cpu_self->isr_nest_level;
+void _AArch64_Exception_frame_copy(
+ CPU_Exception_frame *new_ef,
+ CPU_Exception_frame *old_ef
+ *new_ef = *old_ef;
+int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef )
+ uint64_t EC = AARCH64_ESR_EL1_EC_GET( ef->register_syndrome );
+ switch ( EC ) {
+ case 0x1: /* WFI */
+ case 0x7: /* SVE/SIMD/FP */
+ case 0xa: /* LD64B/ST64B* */
+ case 0x18: /* MSR/MRS/system instruction */
+ case 0x19: /* SVE */
+ case 0x15: /* Supervisor call */
+ case 0x26: /* SP Alignment */
+ case 0x31: /* Breakpoint */
+ case 0x33: /* Step */
+ case 0x35: /* Watchpoint */
+ case 0x3c: /* Break Instruction */
+ return -1;
+ case 0x2c: /* FPU */
+ return SIGFPE;
+ case 0x21: /* Instruction Abort */
+ case 0x25: /* Data Abort */
+ return SIGSEGV;
+ default:
+ return SIGILL;
+void _CPU_Exception_frame_set_resume( CPU_Exception_frame *ef, void *address )
+ ef->register_pc = address;
+#define AARCH64_INSTRUCTION_SIZE 4
+void _CPU_Exception_frame_make_resume_next_instruction( CPU_Exception_frame *ef )
+ ef->register_pc += AARCH64_INSTRUCTION_SIZE;
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index b206f5764b..6344dce63a 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -45,6 +45,8 @@
.globl _AArch64_Exception_interrupt_no_nest
.globl _AArch64_Exception_interrupt_nest
+.globl _CPU_Exception_dispatch_and_resume
+.globl _CPU_Exception_resume
#ifdef RTEMS_SMP
@@ -324,3 +326,166 @@ Return to embedded exception vector code
pop_interrupt_context
/* Return to vector for final cleanup */
ret
+ * This function is expected to resume execution using the CPU_Exception_frame
+ * provided in x0. This function does not adhere to the AAPCS64 calling
+ * convention because all necessary state is contained within the exception
+ * frame.
+_CPU_Exception_resume:
+/* Reset stack pointer */
+ mov sp, x0
+/* call CEF restore routine (doesn't restore lr) */
+ bl .pop_exception_context
+/* get lr from CEF */
+ ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
+/* drop space reserved for CEF */
+ add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
+/* switch to thread stack */
+ msr spsel, #1
+ eret
+ * This function is expected to undo dispatch disabling, perform dispatch, and
+ * resume execution using the CPU_Exception_frame provided in x0. This function
+ * does not adhere to the AAPCS64 calling convention because all necessary
+ * state is contained within the exception frame.
+_CPU_Exception_dispatch_and_resume:
+/* Get per-CPU control of current processor */
+ GET_SELF_CPU_CONTROL SELF_CPU_CONTROL_GET_REG
+ mov sp, x0
+/* Check dispatch disable and perform dispatch if necessary */
+/* Load some per-CPU variables */
+ ldr w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ ldrb w1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
+ ldr w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+ ldr w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* Decrement levels and determine thread dispatch state */
+ eor w1, w1, w0
+ sub w0, w0, #1
+ orr w1, w1, w0
+ orr w1, w1, w2
+ sub w3, w3, #1
+/* Store thread dispatch disable and ISR nest levels */
+ str w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ str w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* store should_skip_thread_dispatch in x22 */
+ mov x22, x1
+ * It is now safe to assume that the source of the exception has been resolved.
+ * Copy the exception frame to the thread stack to be compatible with thread
+ * dispatch. This may arbitrarily clobber corruptible registers since all
+ * important state is contained in the exception frame.
+ * No need to save current LR since this will never return to the caller.
+ bl .move_exception_frame_and_switch_to_thread_stack
+ * Check thread dispatch necessary, ISR dispatch disable and thread dispatch
+ * disable level.
+ cmp x22, #0
+ bne .Lno_need_thread_dispatch_resume
+ bl .AArch64_Perform_Thread_Dispatch
+.Lno_need_thread_dispatch_resume:
+ eret
+/* Assumes sp currently points to the EF on the exception stack and SPSel is 0 */
+.move_exception_frame_and_switch_to_thread_stack:
+ mov x1, sp /* Set x1 to the current exception frame */
+ msr spsel, #1 /* switch to thread stack */
+ ldr x0, [x1, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET] /* Get thread SP from exception frame since it may have been updated */
+ mov sp, x0
+ mov x0, sp /* Set x0 to the new exception frame */
+ mov x20, lr /* Save LR */
+ bl _AArch64_Exception_frame_copy /* Copy exception frame to reserved thread stack space */
+ mov lr, x20 /* Restore LR */
+ msr spsel, #0 /* switch to exception stack */
+ add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE /* release space for CEF on exception stack */
+ ret
+ * Apply the exception frame to the current register status, SP points to the EF
+.pop_exception_context:
+/* Pop daif and spsr */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
+/* Restore daif and spsr */
+ msr DAIF, x2
+ msr SPSR_EL1, x3
+/* Pop FAR and ESR */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
+/* Restore ESR and FAR */
+ msr ESR_EL1, x2
+ msr FAR_EL1, x3
+/* Pop fpcr and fpsr */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
+/* Restore fpcr and fpsr */
+ msr FPSR, x2
+ msr FPCR, x3
+/* Pop VFP registers */
+ ldp q0, q1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
+ ldp q2, q3, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
+ ldp q4, q5, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
+ ldp q6, q7, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
+ ldp q8, q9, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
+ ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
+ ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
+ ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
+ ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
+ ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
+ ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
+ ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
+ ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
+ ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
+ ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
+ ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
+/* Pop x0-x29(fp) */
+ ldp x2, x3, [sp, #0x10]
+ ldp x4, x5, [sp, #0x20]
+ ldp x6, x7, [sp, #0x30]
+ ldp x8, x9, [sp, #0x40]
+ ldp x10, x11, [sp, #0x50]
+ ldp x12, x13, [sp, #0x60]
+ ldp x14, x15, [sp, #0x70]
+ ldp x16, x17, [sp, #0x80]
+ ldp x18, x19, [sp, #0x90]
+ ldp x20, x21, [sp, #0xa0]
+ ldp x22, x23, [sp, #0xb0]
+ ldp x24, x25, [sp, #0xc0]
+ ldp x26, x27, [sp, #0xd0]
+ ldp x28, x29, [sp, #0xe0]
+/* Pop ELR, SP already popped */
+ ldr x1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET + 0x8)]
+/* Restore exception LR */
+ msr ELR_EL1, x1
+ ldp x0, x1, [sp, #0x00]
+/* We must clear reservations to ensure consistency with atomic operations */
+ clrex
+ ret
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index ae7e2bdcba..e1d9f0a5c2 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -524,6 +524,27 @@ typedef struct {
void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+RTEMS_NO_RETURN void _CPU_Exception_resume( CPU_Exception_frame *frame );
+_CPU_Exception_dispatch_and_resume( CPU_Exception_frame *frame );
+void _CPU_Exception_disable_thread_dispatch( void );
+int _CPU_Exception_frame_get_signal( CPU_Exception_frame *frame );
+void _CPU_Exception_frame_set_resume( CPU_Exception_frame *frame,
+ void *address );
+ CPU_Exception_frame *frame
void _AArch64_Exception_default( CPU_Exception_frame *frame );
/** Type that can store a 32-bit integer or a pointer. */
diff --git a/spec/build/cpukit/optexceptionextensions.yml b/spec/build/cpukit/optexceptionextensions.yml
index 1bc6d8686f..67c787e7dd 100644
--- a/spec/build/cpukit/optexceptionextensions.yml
+++ b/spec/build/cpukit/optexceptionextensions.yml
@@ -13,6 +13,7 @@ description: |
Enable the RTEMS Exception Extensions for manipulating and acting on exception
frames.
enabled-by:
+- aarch64
links: []
type: build
2.30.2
