[PATCH v4 4/5] cpukit: Add signal mapping support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Oct 28 21:12:02 UTC 2021
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
cpukit/doxygen/appl-config.h | 23 +++++
cpukit/include/rtems/confdefs/extensions.h | 7 ++
cpukit/include/rtems/score/exception.h | 71 ++++++++++++++
cpukit/score/src/exceptionmapping.c | 104 +++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 3 +
spec/build/cpukit/objexceptionmapping.yml | 15 +++
6 files changed, 223 insertions(+)
create mode 100644 cpukit/include/rtems/score/exception.h
create mode 100644 cpukit/score/src/exceptionmapping.c
create mode 100644 spec/build/cpukit/objexceptionmapping.yml
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index c0e5b0b717..4735af8766 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -1773,6 +1773,29 @@
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+/* Generated from spec:/acfg/if/exception-to-signal-mapping */
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the machine exception to
+ * POSIX signal mapping is configured during system initialization.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver is responsible for setting up a mapping from machine
+ * exceptions to POSIX signals so that applications may consume them and alter
+ * task execution as necessary.
+ * This is especially useful for applications written in Ada or C++.
+ * @endparblock
+#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
/* Generated from spec:/acfg/if/max-drivers */
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index 83d690d50a..6492407934 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -93,6 +93,10 @@
#include <rtems/stackchk.h>
#endif
+#ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+ #include <rtems/score/exception.h>
+#endif
#ifdef __cplusplus
extern "C" {
#endif
@@ -103,6 +107,9 @@ extern "C" {
|| defined(CONFIGURE_INITIAL_EXTENSIONS) \
|| defined(BSP_INITIAL_EXTENSION)
const User_extensions_Table _User_extensions_Initial_extensions[] = {
+ #ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+ { .fatal = _Exception_Raise_signal },
+ #endif
#ifdef _CONFIGURE_RECORD_NEED_EXTENSION
#ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
diff --git a/cpukit/include/rtems/score/exception.h b/cpukit/include/rtems/score/exception.h
new file mode 100644
index 0000000000..979a5aae7e
--- /dev/null
+++ b/cpukit/include/rtems/score/exception.h
@@ -0,0 +1,71 @@
+ * @file
+ * @ingroup RTEMSScoreException
+ * @brief This header file provides the interfaces for mapping
+ * exceptions to signsls.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_EXCEPTION_H
+#define _RTEMS_EXCEPTION_H
+#include <rtems/fatal.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSScoreException Exception Mapping Interfaces
+ * @brief This group contains the interfaces for mapping machine exceptions to
+ * signals using the fatal error handler.
+ * @brief Handle an exception frame for the purpose of mapping signals
+ * See CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING documentation in the
+ * "RTEMS Classic API Guide".
+void _Exception_Raise_signal(
+ Internal_errors_Source source,
+ bool always_set_to_false,
+ Internal_errors_t code
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_EXCEPTION_H */
diff --git a/cpukit/score/src/exceptionmapping.c b/cpukit/score/src/exceptionmapping.c
index 0000000000..1baa047eb7
--- /dev/null
+++ b/cpukit/score/src/exceptionmapping.c
@@ -0,0 +1,104 @@
+ * @file
+ * @ingroup RTEMSScoreExceptionMapping
+ * @brief AArch64 machine exception to POSIX signal mapping.
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <pthread.h>
+#include <signal.h>
+#include <rtems/score/exception.h>
+#include <rtems/score/thread.h>
+#include <rtems/score/threadimpl.h>
+static _Thread_local int raise_signal;
+static _Thread_local Thread_Action _Exception_Raise_signal_action;
+static void _Exception_Raise_handler(
+ Thread_Control *executing,
+ Thread_Action *action,
+ ISR_lock_Context *lock_context
+ _Thread_State_release( executing, lock_context );
+ raise( raise_signal );
+ _Thread_State_acquire( executing, lock_context );
+ * Exception handler. Map the exception class to SIGFPE, SIGSEGV
+ * or SIGILL for Ada or other runtimes.
+ CPU_Exception_frame *ef;
+ Per_CPU_Control *cpu_self = _Per_CPU_Get();
+ bool system_up;
+ if ( source != RTEMS_FATAL_SOURCE_EXCEPTION ) {
+ return;
+ /* If the CPU isn't UP yet, there isn't anything to send a signal to */
+#ifdef RTEMS_SMP
+ system_up = ( _Per_CPU_Get_state( cpu_self ) == PER_CPU_STATE_UP );
+#else
+ system_up = ( _System_state_Get == SYSTEM_STATE_UP );
+#endif
+ if ( !system_up ) {
+ return;
+ ef = (rtems_exception_frame *) code;
+ raise_signal = _CPU_Exception_frame_get_signal( ef );
+ if ( raise_signal < 0 ) {
+ return;
+ _Thread_Add_post_switch_action(
+ _Per_CPU_Get_executing( cpu_self ),
+ &_Exception_Raise_signal_action,
+ _Exception_Raise_handler
+ /* Disable thread dispatch so that dispatch can occur */
+ _CPU_Exception_disable_thread_dispatch();
+ /* Perform dispatch and resume execution */
+ _CPU_Exception_dispatch_and_resume( ef );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2017ab058c..2b25b5dcce 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -343,6 +343,7 @@ install:
- cpukit/include/rtems/score/coresem.h
- cpukit/include/rtems/score/coresemimpl.h
- cpukit/include/rtems/score/cpustdatomic.h
+ - cpukit/include/rtems/score/exception.h
- cpukit/include/rtems/score/freechain.h
- cpukit/include/rtems/score/hash.h
- cpukit/include/rtems/score/heap.h
@@ -497,6 +498,8 @@ links:
uid: objdl
- role: build-dependency
uid: objdrvmgr
+- role: build-dependency
+ uid: objexceptionmapping
uid: objgnat
diff --git a/spec/build/cpukit/objexceptionmapping.yml b/spec/build/cpukit/objexceptionmapping.yml
index 0000000000..40f559c73f
--- /dev/null
+++ b/spec/build/cpukit/objexceptionmapping.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_EXCEPTION_EXTENSIONS
+includes: []
+install: []
+links: []
+source:
+- cpukit/score/src/exceptionmapping.c
+type: build
2.30.2
