[PATCH RSB] Update to dtc 1.6.1
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Fri Oct 29 06:44:34 UTC 2021
On Fri, 29 Oct 2021 at 01:37, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Oct 28, 2021, 6:25 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 29/10/21 6:26 am, Joel Sherrill wrote:
> > > On Thu, Oct 28, 2021 at 12:20 PM Hesham Almatary
> > > <hesham.almatary at cl.cam.ac.uk> wrote:
> > >> Does RISC-V need that too?
> > > Not based on the current bsets.
Right, it is required only for Spike, which uses devel/dtc pointing to
DTC 1.4.1 version.
https://github.com/RTEMS/rtems-source-builder/blob/master/bare/config/devel/spike.bset#L7
> > > $ grep -r dtc *
> > > 6/rtems-moxie.bset:devel/dtc-1.6.0-1
> > > 6/rtems-microblaze.bset:devel/dtc-1.6.0-1
> > > 7/rtems-moxie.bset:devel/dtc-1.6.0-1
> > > Alex.. the grep shows that 7/microblaze is out of sync. Please address
> > that.
> > > Hesham.. if riscv needs dtc, it should be added to its bset for 6 and 7.
> > Should we add DTC to the default package set and avoid the need to manage
> > what
> > needs it?
> > The rational is the growing use of FDT in RTEMS and this lets us control
> > what we
> > need on a per release basis. For example 5 years from now DTC has changed
> > and
> > RTEMS today does not work with it.
> I think that is a really good idea. DTC broke a handful architecture tools
> when it wouldn't build on FreeBSD 13. If we had to build it for every
> architecture oh, then it would have gotten addressed quicker.
> And your logic that is a commonly used tool is also quite true. It isn't a
> huge burden.
> Perhaps Alex can do this as a follow-up patch after this
> --joel
> > Chris
> devel mailing list
> devel at rtems.org
