[PATCH v1 6/8] bsps/aarch64: Set interrupt level correctly
Kinsey Moore kinsey.moore at oarcorp.com
Fri Oct 29 21:17:19 UTC 2021
The existing code is functional but inccorrect and blindly modifies the
other masking bits. It is important to preserve those other bits since
they control masking of important system events.
 bsps/aarch64/include/dev/irq/arm-gic-arch.h |  2 +-
 cpukit/score/cpu/aarch64/cpu.c              | 16 +++++++++++-----
 2 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/bsps/aarch64/include/dev/irq/arm-gic-arch.h b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
index 0911320851..049a1c8555 100644
--- a/bsps/aarch64/include/dev/irq/arm-gic-arch.h
+++ b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
@@ -49,7 +49,7 @@ extern "C" {
 static inline void arm_interrupt_handler_dispatch(rtems_vector_number vector)
   uint32_t interrupt_level = _CPU_ISR_Get_level();
-  AArch64_interrupt_enable(1);
+  _CPU_ISR_Set_level(1);
   bsp_interrupt_handler_dispatch(vector);
   _CPU_ISR_Set_level(interrupt_level);
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index b36f55ae17..88e7ad8a8c 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -149,11 +149,17 @@ void _CPU_Context_Initialize(
 void _CPU_ISR_Set_level( uint32_t level )
   /* Set the mask bit if interrupts are disabled */
-  level = level ? AARCH64_PSTATE_I : 0;
-  __asm__ volatile (
-    "msr DAIF, %[level]\n"
-    : : [level] "r" (level)
+  if ( level ) {
+    __asm__ volatile (
+      "msr DAIFSet, #0x2\n"
+      : : [level] "r" (level)
+  } else {
+      "msr DAIFClr, #0x2\n"
 uint32_t _CPU_ISR_Get_level( void )
2.30.2
