[PATCH] score: Document Futex Handler
Wed Sep 1 12:56:42 UTC 2021
On 01/09/2021 14:45, Joel Sherrill wrote:
> The comment says behaviour. Do we provide a compatible API at some level?
To some extent the API is compatible. The futex support is used for the
OpenMP support in GCC (libgomp). We are able to use the Linux futex
barrier implementation nearly one-to-one. The main difference is that in
RTEMS we directly provide a futex object which contains the thread
queue. In Linux a mapping from the physical address of the futex state
to some futex object must be done.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
