[PATCH v1 3/5] cpukit/aarch64: Add Exception Manager support
Sebastian Huber
Wed Sep 1 15:58:04 UTC 2021
On 01/09/2021 17:48, Sebastian Huber wrote:
> So, my proposal would be something like this:
> 1. Processor jumps to exception prologue
> 2. Exception prologue saves the context to CPU exception frame
> 3. Exception prologue calls rtems_fatal() which does not return
> For the signal mapping you provide a fatal extension:
> 1. If the source is not RTEMS_FATAL_SOURCE_EXCEPTION, then return
> (system terminates).
> 2. If the exception type cannot be handled, then return (system
> terminates).
> 3. Add a post-switch action to the executing thread.
> 4. Call _CPU_Exception_return( frame )
> The _CPU_Exception_return( frame ) should:
> 1. Save the CPU exception return information to the stack of the
> executing thread.
> 2. Switch to the stack of the executing thread and to thread context
> with interrupts disabled.
> 3. Do something similar to the interrupt return.
> 4. The thread dispatch will call the post-switch extension which could
> raise a signal.
> This approach avoids a new user extension and it avoids a potentially
> dead code in the exception epilogue.
Chris, I guess you have something like this
in libdebugger currently?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
