[PATCH 2/5] score: Fix blocking message queue receive
Gedare Bloom
gedare at rtems.org
Wed Sep 1 16:58:38 UTC 2021
On Tue, Aug 31, 2021 at 5:24 AM Sebastian Huber
> In order to ensure FIFO fairness across schedulers, the thread queue
> surrender operation must be used to dequeue a thread from the thread
> queue. The thread queue extract operation is intended for timeouts.
Please add a note like this to the doxygen for _Thread_queue_Extract().
> Add _Thread_queue_Resume() which may be used to make extracted or
> surrendered threads ready again.
> Remove the now unused _Thread_queue_Extract_critical() function.
> Close #4509.
> cpukit/include/rtems/score/coremsgimpl.h | 20 ++++----
> cpukit/include/rtems/score/threadqimpl.h | 59 ++++++------------------
> cpukit/score/src/coremsgseize.c | 20 ++++----
> cpukit/score/src/threadqenqueue.c | 45 ++++++++++--------
> 4 files changed, 62 insertions(+), 82 deletions(-)
> diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
> index 161cf8f124..7f01769010 100644
> --- a/cpukit/include/rtems/score/coremsgimpl.h
> +++ b/cpukit/include/rtems/score/coremsgimpl.h
> @@ -616,7 +616,8 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
> Thread_queue_Context *queue_context
> - Thread_Control *the_thread;
> + Thread_queue_Heads *heads;
> + Thread_Control *the_thread;
> * If there are pending messages, then there can't be threads
> @@ -634,14 +635,18 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
> * There must be no pending messages if there is a thread waiting to
> * receive a message.
> - the_thread = _Thread_queue_First_locked(
> - &the_message_queue->Wait_queue,
> - the_message_queue->operations
> - if ( the_thread == NULL ) {
> + heads = the_message_queue->Wait_queue.Queue.heads;
> + if ( heads == NULL ) {
> return NULL;
> + the_thread = ( *the_message_queue->operations->surrender )(
> + &the_message_queue->Wait_queue.Queue,
> + heads,
> + NULL,
> + queue_context
> *(size_t *) the_thread->Wait.return_argument = size;
> the_thread->Wait.count = (uint32_t) submit_type;
> @@ -651,9 +656,8 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
> size
> - _Thread_queue_Extract_critical(
> + _Thread_queue_Resume(
> - the_message_queue->operations,
> the_thread,
> queue_context
> diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
> index 2465fc4499..0a24d2da3b 100644
> --- a/cpukit/include/rtems/score/threadqimpl.h
> +++ b/cpukit/include/rtems/score/threadqimpl.h
> @@ -975,56 +975,23 @@ void _Thread_queue_Unblock_critical(
> - * @brief Extracts the thread from the thread queue and unblocks it.
> + * @brief Resumes the extracted or surrendered thread.
> - * The caller must be the owner of the thread queue lock. This function will
> - * release the thread queue lock and restore the default thread lock. Thread
> - * dispatching is disabled before the thread queue lock is released and an
> - * unblock is necessary. Thread dispatching is enabled once the sequence to
> - * unblock the thread is complete. This makes it possible to use the thread
> - * queue lock to protect the state of objects embedding the thread queue and
> - * directly enter _Thread_queue_Extract_critical() to finalize an operation in
> - * case a waiting thread exists.
> - * @code
> - * #include <rtems/score/threadqimpl.h>
> - * typedef struct {
> - * Thread_queue_Control Queue;
> - * Thread_Control *owner;
> - * } Mutex;
> + * This function makes the thread ready again. If necessary, the thread is
> + * unblocked and its thread timer removed.
> - * void _Mutex_Release( Mutex *mutex )
> - * Thread_queue_Context queue_context;
> - * Thread_Control *first;
> - * _Thread_queue_Context_initialize( &queue_context, NULL );
> - * _Thread_queue_Acquire( &mutex->Queue, queue_context );
> - * first = _Thread_queue_First_locked( &mutex->Queue );
> - * mutex->owner = first;
> - * if ( first != NULL ) {
> - * _Thread_queue_Extract_critical(
> - * &mutex->Queue.Queue,
> - * mutex->Queue.operations,
> - * first,
> - * &queue_context
> - * @endcode
> + * The thread shall have been extracted from the thread queue or surrendered by
> + * the thread queue right before the call to this function. The caller shall
> + * be the owner of the thread queue lock.
> - * @param queue The actual thread queue.
> - * @param operations The thread queue operations.
> - * @param[in, out] the_thread The thread to extract.
> - * @param[in, out] queue_context The thread queue context of the lock acquire.
> + * @param queue is the actual thread queue.
> + * @param[in, out] the_thread is the thread to make ready and unblock.
> + * @param[in, out] queue_context is the thread queue context.
> -void _Thread_queue_Extract_critical(
> - Thread_queue_Queue *queue,
> - const Thread_queue_Operations *operations,
> - Thread_Control *the_thread,
> - Thread_queue_Context *queue_context
> +void _Thread_queue_Resume(
> + Thread_queue_Queue *queue,
> + Thread_Control *the_thread,
> + Thread_queue_Context *queue_context
> diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
> index e44538ee17..148e9dbb3c 100644
> --- a/cpukit/score/src/coremsgseize.c
> +++ b/cpukit/score/src/coremsgseize.c
> @@ -56,7 +56,8 @@ Status_Control _CORE_message_queue_Seize(
> return STATUS_SUCCESSFUL;
> #else
> * There could be a thread waiting to send a message. If there
> @@ -65,11 +66,8 @@ Status_Control _CORE_message_queue_Seize(
> * NOTE: If we note that the queue was not full before this receive,
> * then we can avoid this dequeue.
> _CORE_message_queue_Free_message_buffer(
> the_message_queue,
> the_message
> @@ -78,6 +76,13 @@ Status_Control _CORE_message_queue_Seize(
> + heads,
> + NULL,
> + queue_context
> * There was a thread waiting to send a message. This code
> * puts the messages in the message queue on behalf of the
> @@ -90,9 +95,8 @@ Status_Control _CORE_message_queue_Seize(
> (size_t) the_thread->Wait.option,
> (CORE_message_queue_Submit_types) the_thread->Wait.count
> the_thread,
> queue_context
> diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
> index d165e30da7..833d37ee61 100644
> --- a/cpukit/score/src/threadqenqueue.c
> +++ b/cpukit/score/src/threadqenqueue.c
> @@ -7,9 +7,10 @@
> * _Thread_queue_Deadlock_fatal(), _Thread_queue_Deadlock_status(),
> * _Thread_queue_Do_dequeue(), _Thread_queue_Enqueue(),
> * _Thread_queue_Enqueue_do_nothing_extra(), _Thread_queue_Enqueue_sticky(),
> - * _Thread_queue_Extract(), _Thread_queue_Extract_critical(),
> - * _Thread_queue_Extract_locked(), _Thread_queue_Path_acquire_critical(),
> - * _Thread_queue_Path_release_critical(), _Thread_queue_Surrender(),
> + * _Thread_queue_Extract(), _Thread_queue_Extract_locked(),
> + * _Thread_queue_Path_acquire_critical(),
> + * _Thread_queue_Path_release_critical(),
> + * _Thread_queue_Resume(),_Thread_queue_Surrender(),
> * _Thread_queue_Surrender_sticky(), and _Thread_queue_Unblock_critical().
> @@ -604,28 +605,32 @@ void _Thread_queue_Unblock_critical(
> bool unblock;
> - unblock = _Thread_queue_Extract_locked(
> - queue,
> - operations,
> - the_thread,
> - queue_context
> + unblock = _Thread_queue_Make_ready_again( the_thread );
> - _Thread_queue_Unblock_critical(
> - unblock,
> - queue,
> - the_thread,
> - &queue_context->Lock_context.Lock_context
> + if ( unblock ) {
> + Per_CPU_Control *cpu_self;
> + cpu_self = _Thread_queue_Dispatch_disable( queue_context );
> + _Thread_queue_Queue_release(
> + queue, &queue_context->Lock_context.Lock_context
> + _Thread_Remove_timer_and_unblock( the_thread, queue );
> + _Thread_Dispatch_enable( cpu_self );
> + } else {
> void _Thread_queue_Extract( Thread_Control *the_thread )
> 2.26.2
> devel mailing list
> devel at rtems.org
