[PATCH rtems v1 1/2] bsps/zynq: Moved general i2c files to shared directories
Gedare Bloom
gedare at rtems.org
Wed Sep 1 17:02:14 UTC 2021
looks fine to me.
On Mon, Aug 23, 2021 at 4:41 PM Stephen Clark <stephen.clark at oarcorp.com> wrote:
> Certain files related to the Zynq BSP's I2C driver are useable by the ZynqMP BSP as well.
> Moved these files to shared directory in anticipation of I2C support for ZynqMP.
> .../include/bsp => include/dev/i2c}/cadence-i2c-regs.h | 0
> .../include/bsp => include/dev/i2c}/cadence-i2c.h | 0
> bsps/{arm/xilinx-zynq => shared/dev}/i2c/cadence-i2c.c | 4 ++--
> spec/build/bsps/arm/xilinx-zynq/obj.yml | 6 +++---
> 4 files changed, 5 insertions(+), 5 deletions(-)
> rename bsps/{arm/xilinx-zynq/include/bsp => include/dev/i2c}/cadence-i2c-regs.h (100%)
> rename bsps/{arm/xilinx-zynq/include/bsp => include/dev/i2c}/cadence-i2c.h (100%)
> rename bsps/{arm/xilinx-zynq => shared/dev}/i2c/cadence-i2c.c (99%)
> diff --git a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h b/bsps/include/dev/i2c/cadence-i2c-regs.h
> similarity index 100%
> rename from bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
> rename to bsps/include/dev/i2c/cadence-i2c-regs.h
> diff --git a/bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h b/bsps/include/dev/i2c/cadence-i2c.h
> rename from bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
> rename to bsps/include/dev/i2c/cadence-i2c.h
> diff --git a/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c b/bsps/shared/dev/i2c/cadence-i2c.c
> similarity index 99%
> rename from bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
> rename to bsps/shared/dev/i2c/cadence-i2c.c
> index 07379992ce..91774fb926 100644
> --- a/bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
> +++ b/bsps/shared/dev/i2c/cadence-i2c.c
> @@ -25,8 +25,8 @@
> * POSSIBILITY OF SUCH DAMAGE.
> -#include <bsp/cadence-i2c.h>
> -#include <bsp/cadence-i2c-regs.h>
> +#include <dev/i2c/cadence-i2c.h>
> +#include <dev/i2c/cadence-i2c-regs.h>
> #include <rtems/irq-extension.h>
> #include <rtems/score/assert.h>
> diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> index e81decaa3d..8a11a45dd3 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> @@ -14,8 +14,8 @@ install:
> - bsps/arm/xilinx-zynq/include/tm27.h
> - destination: ${BSP_INCLUDEDIR}/bsp
> source:
> - - bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h
> - - bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h
> + - bsps/include/dev/i2c/cadence-i2c-regs.h
> + - bsps/include/dev/i2c/cadence-i2c.h
> - bsps/arm/xilinx-zynq/include/bsp/i2c.h
> - bsps/arm/xilinx-zynq/include/bsp/irq.h
> links: []
> @@ -28,7 +28,7 @@ source:
> - bsps/arm/xilinx-zynq/console/console-config.c
> - bsps/arm/xilinx-zynq/console/console-init.c
> - bsps/arm/xilinx-zynq/console/debug-console.c
> -- bsps/arm/xilinx-zynq/i2c/cadence-i2c.c
> +- bsps/shared/dev/i2c/cadence-i2c.c
> - bsps/arm/xilinx-zynq/start/bspreset.c
> - bsps/arm/xilinx-zynq/start/bspstart.c
> - bsps/arm/xilinx-zynq/start/bspstarthooks.c
> 2.27.0
> devel mailing list
> devel at rtems.org
