[PATCH] score: Document thread queue operations
Chris Johns
chrisj at rtems.org
Thu Sep 2 06:38:47 UTC 2021
On 2/9/21 3:50 pm, Sebastian Huber wrote:
> cpukit/include/rtems/score/threadq.h | 44 ++++++++++++++++++------
> cpukit/include/rtems/score/threadqimpl.h | 17 +++++++++
> 2 files changed, 51 insertions(+), 10 deletions(-)
> diff --git a/cpukit/include/rtems/score/threadq.h b/cpukit/include/rtems/score/threadq.h
> index 10476888d4..0362f84c98 100644
> --- a/cpukit/include/rtems/score/threadq.h
> +++ b/cpukit/include/rtems/score/threadq.h
> @@ -406,6 +406,7 @@ typedef struct _Thread_queue_Heads {
> } Thread_queue_Heads;
> struct Thread_queue_Queue {
> +#if defined(RTEMS_SMP)
> * @brief Lock to protect this thread queue.
> @@ -418,7 +419,6 @@ struct Thread_queue_Queue {
> * @see _Thread_queue_Acquire(), _Thread_queue_Acquire_critical() and
> * _Thread_queue_Release().
> -#if defined(RTEMS_SMP)
> SMP_ticket_lock_Control Lock;
> #endif
> @@ -517,37 +517,61 @@ typedef Thread_Control *( *Thread_queue_First_operation )(
> - * @brief Thread queue operations.
> + * @brief The thread queue operations are used to implement the addition and
> + * removal of threads to and from a thread queue and related tasks.
Addition and removal? Is there something better, insert and extract?
> + * The standard thread queue operation variants are:
> + * * ::_Thread_queue_Operations_default
> + * * ::_Thread_queue_Operations_FIFO
> + * * ::_Thread_queue_Operations_priority
> + * * ::_Thread_queue_Operations_priority_inherit
> * @see _Thread_wait_Set_operations().
> struct Thread_queue_Operations {
> - * @brief Thread queue priority actions operation.
> + * @brief This operation performs the thread queue priority actions.
> + * Priority actions are produced and processed during enqueue, extract, and
> + * surrender operations.
> Thread_queue_Priority_actions_operation priority_actions;
> - * @brief Thread queue enqueue operation.
> - * Called by object routines to enqueue the thread.
> + * @brief This operation is used to enqueue the thread on the thread queue.
Where in the queue is the thread inserted?
> Thread_queue_Enqueue_operation enqueue;
> - * @brief Thread queue extract operation.
> + * @brief This operation is used to extract the thread from the thread queue.
> - * Called by object routines to extract a thread from a thread queue.
> + * The extract operation is intended for timeouts, thread restarts, and
> + * thread cancellation. The surrender operation should be used to dequeue a
> + * thread from the thread queue.
>From the start, end, or where it is in the queue?
> Thread_queue_Extract_operation extract;
> - * @brief Thread queue surrender operation.
> + * @brief This operation is used to dequeue the thread from the thread queue
> + * and optionally surrender the thread queue from a previous owner.
> + * In addition to the optional surrender, there is a subtle difference
> + * between the extract and dequeue of a thread from a thread queue. In SMP
> + * configurations, FIFO fairness across schedulers for priority queues is
> + * only ensured for the dequeue operation and not for the extract operation.
Dequeue or extract? There seems to be a mix of terms and I am not 100% if they
are the same or different? There is addition, enqueue, removal, dequeue, extract.
I have read the statement about the difference between dequeue and extract and I
am not sure what it means.
> Thread_queue_Surrender_operation surrender;
> - * @brief Thread queue first operation.
> + * @brief This operation returns the first thread on the thread queue.
> + * This operation shall be called only when the thread queue contains at
> + * least one thread. Use ::Thread_queue_Queue::heads to determine if a
> + * thread queue is empty.
Shall? It is implies this call "shall" be made for every call?
> Thread_queue_First_operation first;
> diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
> index 33cdb3058d..5d3edaf9e0 100644
> --- a/cpukit/include/rtems/score/threadqimpl.h
> +++ b/cpukit/include/rtems/score/threadqimpl.h
> @@ -1396,12 +1396,29 @@ typedef struct {
> Wait_queue.Queue \
> + * @brief The default thread queue operations are used when a thread is not
> + * enqueued on a thread queue.
What is the default set of operations compared to the operations below?
