[PATCH rtems-libbsd] imx: Remove ccm functions alredy defined in RTEMS
Thu Sep 2 06:40:02 UTC 2021
On 2/9/21 4:35 pm, Christian MAUDERER wrote:
> Am 02.09.21 um 04:57 schrieb Chris Johns:
>> On 1/9/21 4:24 pm, Christian MAUDERER wrote:
>>> Hello Gedare and Chris,
>>> Am 01.09.21 um 07:55 schrieb Chris Johns:
>>>> On 1/9/21 7:26 am, Gedare Bloom wrote:
>>>>> Sorry, i think libbsd is still a bit slushy, wait for Chris to ok thx
>>> I planned to wait for Chris work anyway.
>> I have pushed the changes so this change is OK to push. Thank you for your
>> patience and consideration.
>> Chris
> Hello Chris,
> that's great news. Thanks a lot for all your great improvements.
> I noted that currently your patches are only on 6-freebsd-12. Do you plan to
> have the same (or a similar) patch set on master too? Background of the
> question: Normally I would push the patch to both branches. But if you have a
> similar patch set pending for master too, I think it would be a bad timing if I
> push my patch now.
Please push to master. It can be handled as part of that task.
I plan too but it is too big a task to get done unfunded. I have not had time to
look at it.
