[PATCH v2] score: Document thread queue operations
Sebastian Huber
Thu Sep 2 07:13:07 UTC 2021
cpukit/include/rtems/score/threadq.h | 48 +++++++++++++++++++-----
cpukit/include/rtems/score/threadqimpl.h | 21 +++++++++++
cpukit/score/src/threadqops.c | 4 +-
3 files changed, 62 insertions(+), 11 deletions(-)
diff --git a/cpukit/include/rtems/score/threadq.h b/cpukit/include/rtems/score/threadq.h
index 10476888d4..9d1ad84e81 100644
--- a/cpukit/include/rtems/score/threadq.h
+++ b/cpukit/include/rtems/score/threadq.h
@@ -406,6 +406,7 @@ typedef struct _Thread_queue_Heads {
} Thread_queue_Heads;
struct Thread_queue_Queue {
+#if defined(RTEMS_SMP)
* @brief Lock to protect this thread queue.
@@ -418,7 +419,6 @@ struct Thread_queue_Queue {
* @see _Thread_queue_Acquire(), _Thread_queue_Acquire_critical() and
* _Thread_queue_Release().
-#if defined(RTEMS_SMP)
SMP_ticket_lock_Control Lock;
#endif
@@ -517,37 +517,67 @@ typedef Thread_Control *( *Thread_queue_First_operation )(
- * @brief Thread queue operations.
+ * @brief The thread queue operations are used to manage the threads of a
+ * thread queue.
+ * The standard thread queue operation variants are:
+ * * ::_Thread_queue_Operations_default
+ * * ::_Thread_queue_Operations_FIFO
+ * * ::_Thread_queue_Operations_priority
+ * * ::_Thread_queue_Operations_priority_inherit
* @see _Thread_wait_Set_operations().
struct Thread_queue_Operations {
- * @brief Thread queue priority actions operation.
+ * @brief This operation performs the thread queue priority actions.
+ * Priority actions are produced and processed during enqueue, extract, and
+ * surrender operations.
Thread_queue_Priority_actions_operation priority_actions;
- * @brief Thread queue enqueue operation.
+ * @brief This operation is used to enqueue the thread on the thread queue.
- * Called by object routines to enqueue the thread.
+ * The enqueue order is defined by the operations variant.
Thread_queue_Enqueue_operation enqueue;
- * @brief Thread queue extract operation.
+ * @brief This operation is used to extract the thread from the thread queue.
- * Called by object routines to extract a thread from a thread queue.
+ * The extract operation is intended for timeouts, thread restarts, and
+ * thread cancellation. In SMP configurations, the extract operation does
+ * not ensure FIFO fairness across schedulers for priority queues. The
+ * surrender operation should be used to dequeue a thread from the thread
+ * queue under normal conditions (no timeout, no thread restart, and no
+ * thread cancellation).
Thread_queue_Extract_operation extract;
- * @brief Thread queue surrender operation.
+ * @brief This operation is used to dequeue the thread from the thread queue
+ * and optionally surrender the thread queue from a previous owner to the
+ * thread.
+ * In addition to the optional surrender, there is a subtle difference
+ * between the extract and dequeue of a thread from a thread queue. In SMP
+ * configurations, FIFO fairness across schedulers for priority queues is
+ * only ensured for the surrender operation and not for the extract operation.
Thread_queue_Surrender_operation surrender;
- * @brief Thread queue first operation.
+ * @brief This operation returns the first thread on the thread queue.
+ * This operation may be called only when the thread queue contains at least
+ * one thread. Use ::Thread_queue_Queue::heads to determine if a thread
+ * queue is empty.
Thread_queue_First_operation first;
diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
index 33cdb3058d..22e0c7f069 100644
--- a/cpukit/include/rtems/score/threadqimpl.h
+++ b/cpukit/include/rtems/score/threadqimpl.h
@@ -1396,12 +1396,33 @@ typedef struct {
Wait_queue.Queue \
+ * @brief The default thread queue operations are used when a thread is not
+ * enqueued on a thread queue.
+ * The default operations may be used by _Thread_Priority_apply() and
+ * _Thread_Continue() if the thread is not enqueued on a thread queue. The
+ * default operations do nothing.
extern const Thread_queue_Operations _Thread_queue_Operations_default;
+ * @brief The FIFO thread queue operations are used when a thread is enqueued
+ * on a thread queue and provide FIFO ordering of enqueued threads.
extern const Thread_queue_Operations _Thread_queue_Operations_FIFO;
+ * on a thread queue and provide priority ordering of enqueued threads.
extern const Thread_queue_Operations _Thread_queue_Operations_priority;
+ * on a thread queue and provide priority ordering of enqueued threads with
+ * support for priority inheritance.
extern const Thread_queue_Operations _Thread_queue_Operations_priority_inherit;
diff --git a/cpukit/score/src/threadqops.c b/cpukit/score/src/threadqops.c
index eb01002679..6acbce1b42 100644
--- a/cpukit/score/src/threadqops.c
+++ b/cpukit/score/src/threadqops.c
@@ -1464,8 +1464,8 @@ const Thread_queue_Operations _Thread_queue_Operations_default = {
.priority_actions = _Thread_queue_Do_nothing_priority_actions,
.extract = _Thread_queue_Do_nothing_extract
- * The default operations are only used in _Thread_Change_priority() and
- * _Thread_Timeout() and don't have a thread queue associated with them, so
+ * The default operations are only used in _Thread_Priority_apply() and
+ * _Thread_Continue() and don't have a thread queue associated with them, so
* the enqueue and first operations are superfluous.
2.26.2
