[PATCH rtems-libbsd] imx: Remove ccm functions alredy defined in RTEMS
Chris Johns
chrisj at rtems.org
Thu Sep 2 07:33:34 UTC 2021
On 2/9/21 5:18 pm, Christian MAUDERER wrote:
> And already a question regarding the new branch: You cleaned up the
> rtems-bsd-kernel-namespace.h (which is great).
Thanks. It came as a surprise the script broke on FreeBSD.
> My patch removes some duplicated functions that are in RTEMS and in libbsd. The
> ones in RTEMS are definitively the correct ones and the ones in libbsd return
> wrong values sometimes. With your patch, the functions are now in the namespace
> header (which is OK).
OK
> I tried to regenerate the header using the rtems-kern-symbols. But even with the
> --regenerate option like described in the CONTRIBUTING.md, the symbols are not
> removed. I can remove them manually and the rtems-kern-symbols script doesn't
> change the header if I re-run it. So I'm quite sure that this is an OK solution.
> But it somehow feels wrong to manually change a generated header. Is there
> something I used wrong?
No nothing at all.
> What I did:
> - Re-build libbsd and note that the tests don't link any more.
> - run `./rtems-kern-symbols --regenerate --rtems-tools=<path_to_tools>`
> Nothing has been changed.
> - manually remove the symbols
> - re-build (now successfully)
> Nothing has been changed. Symbols are still removed.
> - add symbols manually again
> Nothing has been changed. Symbols are still there.
> So I think my core question is: Does the tool clean up old symbols or do I have
> to do that manually?
You need to remove the lines manually. I could not find a suitable solution that
worked effective and efficiently.
I spent sometime on this and considered a number of options for a while and came
to no workable solution to handle it automatically. An automatic tool that can
remove calls needs to build all combinations of arch/bsps multiplied by all the
possible options for RTEMS and the BSPs multiplied by all libbsd options to know
a symbol is not needed. That was all way too hard.
My compromise solution was adding a report option to help you see what is
happening with the symbols. The intention is to aid managing those symbols you
are interested in.
