[PATCH v1 04/10] CoverageMapBase.cc: Fix formatting
Ryan Long ryan.long at oarcorp.com
Thu Sep 2 19:24:33 UTC 2021
 tester/covoar/CoverageMapBase.cc | 261 ++++++++++++++++++++++++---------------
 1 file changed, 159 insertions(+), 102 deletions(-)
diff --git a/tester/covoar/CoverageMapBase.cc b/tester/covoar/CoverageMapBase.cc
index 334426b..7073260 100644
--- a/tester/covoar/CoverageMapBase.cc
+++ b/tester/covoar/CoverageMapBase.cc
@@ -18,98 +18,109 @@
 namespace Coverage {
-  AddressInfo::AddressInfo ()
-    : isStartOfInstruction (false),
-      wasExecuted (false),
-      isBranch (false),
-      isNop (false),
-      wasTaken (false),
-      wasNotTaken (false)
+  AddressInfo::AddressInfo()
+    : isStartOfInstruction( false ),
+      wasExecuted( false ),
+      isBranch( false ),
+      isNop( false ),
+      wasTaken( false ),
+      wasNotTaken( false )
-  AddressRange::AddressRange ()
-    : lowAddress(0),
-      highAddress(0)
+  AddressRange::AddressRange()
+    : lowAddress( 0 ),
+      highAddress( 0 )
-  AddressRange::AddressRange (const std::string& name,
-                              uint32_t           lowAddress,
-                              uint32_t           highAddress)
-    : fileName (name),
-      lowAddress (lowAddress),
-      highAddress (highAddress)
+    const std::string& name,
+    uint32_t           lowAddress,
+    uint32_t           highAddress)
+    : fileName( name ),
+      lowAddress( lowAddress ),
+      highAddress( highAddress )
-    info.resize( size( ) );
+    info.resize( size() );
-  size_t AddressRange::size () const
+  size_t AddressRange::size() const
     return highAddress - lowAddress + 1;
-  bool AddressRange::inside (uint32_t address) const
+  bool AddressRange::inside( uint32_t address ) const
     return address >= lowAddress && address <= highAddress;
-  AddressInfo& AddressRange::get (uint32_t address)
+  AddressInfo& AddressRange::get( uint32_t address )
-    if ( !inside( address ) )
+    if ( !inside( address ) ) {
       throw rld::error( "address outside range", "AddressRange::get" );
     size_t slot = address - lowAddress;
-    if (slot >= info.size ())
+    if ( slot >= info.size () ) {
       throw rld::error( "address slot not found", "AddressRange::get" );
     return info[slot];
-  const AddressInfo& AddressRange::get (uint32_t address) const
+  const AddressInfo& AddressRange::get( uint32_t address ) const
+    if ( slot >= info.size() ) {
     return info[slot];
-  void AddressRange::dump (std::ostream& out, bool show_slots) const
+  void AddressRange::dump( std::ostream& out, bool show_slots ) const
     rtems::utils::ostream_guard old_state( out );
-    out << std::hex << std::setfill('0')
-        << "Address range: low = " << std::setw(8) << lowAddress
-        << " high = " << std::setw(8) << highAddress
+    out << std::hex << std::setfill( '0' )
+        << "Address range: low = " << std::setw( 8 ) << lowAddress
+        << " high = " << std::setw( 8 ) << highAddress
         << std::endl;
     if (show_slots) {
       size_t slot = 0;
-      for (auto& i : info) {
-            << "0x" << std::setw(8) << slot++ + lowAddress
+      for ( auto& i : info ) {
+            << "0x" << std::setw( 8 ) << slot++ + lowAddress
             << "- isStartOfInstruction:"
-            << (char*) (i.isStartOfInstruction ? "yes" : "no")
+            << (char*) ( i.isStartOfInstruction ? "yes" : "no" )
             << " wasExecuted:"
-            << (char*) (i.wasExecuted ? "yes" : "no")
-            << std::endl
-            << "           isBranch:"
-            << (char*) (i.isBranch ? "yes" : "no")
+            << (char*) ( i.wasExecuted ? "yes" : "no" )
+            << "\n           isBranch:"
+            << (char*) ( i.isBranch ? "yes" : "no" )
             << " wasTaken:"
-            << (char*) (i.wasTaken ? "yes" : "no")
+            << (char*) ( i.wasTaken ? "yes" : "no" )
             << " wasNotTaken:"
-            << (char*) (i.wasNotTaken ? "yes" : "no")
-            << std::dec << std::setfill(' ')
+            << (char*) ( i.wasNotTaken ? "yes" : "no" )
+            << std::dec << std::setfill( ' ' )
             << std::endl;
   CoverageMapBase::CoverageMapBase(
     const std::string& exefileName,
     uint32_t           low,
     uint32_t           high
-    ) : exefileName (exefileName)
+  ) : exefileName( exefileName )
     Ranges.push_back( AddressRange( exefileName, low, high ) );
@@ -125,30 +136,38 @@ namespace Coverage {
   bool CoverageMapBase::validAddress( const uint32_t address ) const
-    for ( auto& r : Ranges )
-      if (r.inside( address ))
+    for ( auto& r : Ranges ) {
+      if ( r.inside( address ) ) {
         return true;
     return false;
-  void CoverageMapBase::dump( void ) const
+  void CoverageMapBase::dump() const
-    std::cerr << "Coverage Map Contents:" << std::endl;
-    for (auto& r : Ranges)
+    std::cerr << "Coverage Map Contents\n";
       r.dump( std::cerr );
   uint32_t CoverageMapBase::getSize() const
     size_t size = 0;
       size += r.size ();
     return size;
   uint32_t CoverageMapBase::getSizeOfRange( size_t index ) const
-    return Ranges.at(index).size();
+    return Ranges.at( index ).size();
   bool CoverageMapBase::getBeginningOfInstruction(
@@ -161,19 +180,20 @@ namespace Coverage {
     AddressRange range;
     status = getRange( address, range );
-    if ( status != true )
+    if ( status != true ) {
       return status;
     start = address;
-    while (start >= range.lowAddress ) {
-      if (isStartOfInstruction( start - range.lowAddress )) {
+    while ( start >= range.lowAddress ) {
+      if ( isStartOfInstruction( start - range.lowAddress ) ) {
         *beginning = start;
         status = true;
         break;
-      else
+      } else {
         start--;
     return status;
@@ -189,189 +209,226 @@ namespace Coverage {
   uint32_t CoverageMapBase::getLowAddressOfRange( size_t index ) const
-    return Ranges.at(index).lowAddress;
+    return Ranges.at( index ).lowAddress;
   bool CoverageMapBase::getRange( uint32_t address, AddressRange& range ) const
     for ( auto r : Ranges ) {
-      if (r.inside( address )) {
-        range.lowAddress = r.lowAddress;
+        range.lowAddress  = r.lowAddress;
         range.highAddress = r.highAddress;
-        range.info = r.info;
+        range.info        = r.info;
         return true;
     return false;
   AddressInfo& CoverageMapBase::getInfo( uint32_t address )
         return r.get( address );
     throw rld::error( "address out of bounds", "CoverageMapBase::getInfo" );
   const AddressInfo& CoverageMapBase::getInfo( uint32_t address ) const
-  void CoverageMapBase::setIsStartOfInstruction(
-    uint32_t    address
+  void CoverageMapBase::setIsStartOfInstruction( uint32_t  address )
-    if ( validAddress( address ) )
+    if ( validAddress( address ) ) {
       getInfo( address ).isStartOfInstruction = true;
   bool CoverageMapBase::isStartOfInstruction( uint32_t address ) const
-    if ( !validAddress( address ) )
+    if ( !validAddress( address ) ) {
       return false;
     return getInfo( address ).isStartOfInstruction;
   void CoverageMapBase::setWasExecuted( uint32_t address )
       getInfo( address ).wasExecuted += 1;
-  void CoverageMapBase::sumWasExecuted( uint32_t address, uint32_t addition)
+  void CoverageMapBase::sumWasExecuted( uint32_t address, uint32_t addition )
       getInfo( address ).wasExecuted += addition;
   bool CoverageMapBase::wasExecuted( uint32_t address ) const
     bool result = false;
-    if ( validAddress( address ) && (getInfo( address ).wasExecuted > 0))
+    if ( validAddress( address ) && ( getInfo( address ).wasExecuted > 0 ) ) {
       result = true;
     return result;
   uint32_t CoverageMapBase::getWasExecuted( uint32_t address ) const
       return 0;
     return getInfo( address ).wasExecuted;
-  void CoverageMapBase::setIsBranch(
-    uint32_t    address
+  void CoverageMapBase::setIsBranch( uint32_t address )
       getInfo( address ).isBranch = true;
   bool CoverageMapBase::isNop( uint32_t address ) const
       return false;
     return getInfo( address ).isNop;
-  void CoverageMapBase::setIsNop(
-    uint32_t    address
+  void CoverageMapBase::setIsNop( uint32_t address )
       return;
     getInfo( address ).isNop = true;
   bool CoverageMapBase::isBranch( uint32_t address ) const
       return false;
     return getInfo( address ).isBranch;
-  void CoverageMapBase::setWasTaken(
-    uint32_t    address
+  void CoverageMapBase::setWasTaken( uint32_t address )
       return;
     getInfo( address ).wasTaken += 1;
-  void CoverageMapBase::setWasNotTaken(
-    uint32_t    address
+  void CoverageMapBase::setWasNotTaken( uint32_t address )
       return;
     getInfo( address ).wasNotTaken += 1;
   bool CoverageMapBase::wasAlwaysTaken( uint32_t address ) const
       return false;
     const AddressInfo& info = getInfo( address );
     return info.wasTaken && !info.wasNotTaken;
   bool CoverageMapBase::wasNeverTaken( uint32_t address ) const
       return false;
     return !info.wasTaken && info.wasNotTaken;
   bool CoverageMapBase::wasNotTaken( uint32_t address ) const
     bool result = true;
       result = false;
-    else if ( getInfo( address ).wasNotTaken <= 0 )
+    } else if ( getInfo( address ).wasNotTaken <= 0 ) {
       result = false;
     return result;
-  void CoverageMapBase::sumWasNotTaken( uint32_t address, uint32_t addition)
+  void CoverageMapBase::sumWasNotTaken( uint32_t address, uint32_t addition )
       getInfo( address ).wasNotTaken += addition;
   uint32_t CoverageMapBase::getWasNotTaken( uint32_t address ) const
       return 0;
     return getInfo( address ).wasNotTaken;
   bool CoverageMapBase::wasTaken( uint32_t address ) const
     bool result = true;
       result = false;
-    else if ( getInfo( address ).wasTaken <= 0 )
+    } else if ( getInfo( address ).wasTaken <= 0 ) {
       result = false;
     return result;
-  void CoverageMapBase::sumWasTaken( uint32_t address, uint32_t addition)
+  void CoverageMapBase::sumWasTaken( uint32_t address, uint32_t addition )
       return;
     getInfo( address ).wasTaken += addition;
   uint32_t CoverageMapBase::getWasTaken( uint32_t address ) const
       return 0;
     return getInfo( address ).wasTaken;
1.8.3.1
