[PATCH v1 00/10] Convert and reformat rtems-tools pt. 1
Ryan Long
ryan.long at oarcorp.com
Fri Sep 3 12:07:28 UTC 2021
I haven't been building these with clang, so I'll make sure to start doing that. I've got a Macbook, so I can test it on there as well.
-----Original Message-----
Sent: Thursday, September 2, 2021 11:59 PM
To: Ryan Long <ryan.long at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH v1 00/10] Convert and reformat rtems-tools pt. 1
On 3/9/21 5:24 am, Ryan Long wrote:
> For this and the following series of patches I followed this series of
> steps.
> 1. Convert a file from the C way of doing things to C++ 2. Go through
> all the files that had to do with the converted file and make the
> formatting consistent.
Looks good and thanks for taking this on.
Have you built this with clang on FreeBSD? I only ask because the minor fix I pushed where clang complained about the `std::ostream::tellp()` return value being compared to `long int` ....
https://lists.rtems.org/pipermail/build/2021-September/028853.html
I suspect if this change build on FreeBSD it will also build on MacOS. Do you have access to a MacOS machine?
There is a new piece of code around `gcount()` and this is the reason for my question.
