[PATCH 0/7] Clean up some CLOCK_REALTIME related issues
Sebastian Huber
Fri Sep 3 13:33:17 UTC 2021
See also:
https://lists.rtems.org/pipermail/devel/2021-May/067247.html
https://devel.rtems.org/ticket/4338
Sebastian Huber (7):
score: Return status in _TOD_Adjust()
score: Remove TOD_TICKS_PER_SECOND_method()
score: Add _TOD_Is_valid_new_time_of_day()
score: Limit the CLOCK_REALTIME setting
score: Simplify _TOD_Validate()
score: Always validate ticks in _TOD_Validate()
score: Change TOD_LATEST_YEAR to 2099
bsps/arm/altera-cyclone-v/rtc/rtc.c | 4 +-
bsps/bfin/shared/dev/rtc.c | 9 +--
bsps/shared/dev/rtc/rtc-support.c | 2 +-
cpukit/Makefile.am | 2 +-
cpukit/include/rtems/rtems/clockimpl.h | 28 +--------
cpukit/include/rtems/score/todimpl.h | 79 ++++++++++++++++++-------
cpukit/posix/src/adjtime.c | 6 +-
cpukit/posix/src/clocksettime.c | 5 ++
cpukit/rtems/src/clockgettod.c | 6 +-
cpukit/rtems/src/clockset.c | 2 +-
cpukit/rtems/src/clocktodtoseconds.c | 33 +++--------
cpukit/rtems/src/clocktodvalidate.c | 62 ++++++++++---------
cpukit/rtems/src/taskwakewhen.c | 2 +-
cpukit/rtems/src/timercreate.c | 2 +-
cpukit/score/src/coretodadjust.c | 12 +++-
cpukit/score/src/coretodcheck.c | 59 ++++++++++++++++++
cpukit/score/src/coretodset.c | 22 +------
cpukit/score/src/coretodtickspersec.c | 30 ----------
spec/build/cpukit/librtemscpu.yml | 2 +-
testsuites/psxtests/psxclock/init.c | 15 +++++
testsuites/sptests/sp2038/init.c | 47 +++------------
testsuites/sptests/spclock_err02/init.c | 8 +--
testsuites/sptests/sptask_err02/init.c | 5 +-
23 files changed, 222 insertions(+), 220 deletions(-)
create mode 100644 cpukit/score/src/coretodcheck.c
delete mode 100644 cpukit/score/src/coretodtickspersec.c
2.26.2
