[PATCH 3/7] score: Add _TOD_Is_valid_new_time_of_day()
Fri Sep 3 13:33:20 UTC 2021
Move the TOD validation to the callers of _TOD_Set().  This avoids dead code in
case only rtems_clock_set() is used in an application because rtems_clock_set()
always calls _TOD_Set() with a valid time of day.
 cpukit/Makefile.am                   |  1 +
 cpukit/include/rtems/score/todimpl.h | 14 ++++++-
 cpukit/posix/src/clocksettime.c      |  5 +++
 cpukit/score/src/coretodadjust.c     |  7 +++-
 cpukit/score/src/coretodcheck.c      | 59 ++++++++++++++++++++++++++++
 cpukit/score/src/coretodset.c        | 22 +----------
 spec/build/cpukit/librtemscpu.yml    |  1 +
 7 files changed, 87 insertions(+), 22 deletions(-)
 create mode 100644 cpukit/score/src/coretodcheck.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index cc6bd48a9b..a883941c9a 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1005,6 +1005,7 @@ librtemscpu_a_SOURCES += score/src/timespecgetasnanoseconds.c
 librtemscpu_a_SOURCES += score/src/coretod.c
 librtemscpu_a_SOURCES += score/src/coretodset.c
 librtemscpu_a_SOURCES += score/src/coretodadjust.c
+librtemscpu_a_SOURCES += score/src/coretodcheck.c
 librtemscpu_a_SOURCES += score/src/watchdoginsert.c
 librtemscpu_a_SOURCES += score/src/coretodhookdata.c
 librtemscpu_a_SOURCES += score/src/coretodhookregister.c
diff --git a/cpukit/include/rtems/score/todimpl.h b/cpukit/include/rtems/score/todimpl.h
index 5346f12e53..ceeef2e21b 100644
--- a/cpukit/include/rtems/score/todimpl.h
+++ b/cpukit/include/rtems/score/todimpl.h
@@ -206,13 +206,25 @@ static inline void _TOD_Release( ISR_lock_Context *lock_context )
   _Timecounter_Release( lock_context );
+ * @brief Checks the time point is a valid new time of day for _TOD_Set().
+ * @param tod the time of day to check.
+ * @retval STATUS_SUCCESSFUL The time of day is valid.
+ * @retval STATUS_INVALID_NUMBER The time of day is invalid.
+Status_Control _TOD_Is_valid_new_time_of_day( const struct timespec *tod );
  * @brief Sets the time of day.
  * The caller must be the owner of the TOD lock.
  * @param tod The new time of day in timespec format representing
- *   the time since UNIX Epoch.
+ *   the time since UNIX Epoch.  The new time of day shall be valid according
+ *   to _TOD_Is_valid_new_time_of_day().
  * @param lock_context The ISR lock context used for the corresponding
  *   _TOD_Acquire().  The caller must be the owner of the TOD lock.  This
  *   function will release the TOD lock.
diff --git a/cpukit/posix/src/clocksettime.c b/cpukit/posix/src/clocksettime.c
index 53e728762e..23bb14a86d 100644
--- a/cpukit/posix/src/clocksettime.c
+++ b/cpukit/posix/src/clocksettime.c
@@ -41,6 +41,11 @@ int clock_settime(
   if ( clock_id == CLOCK_REALTIME ) {
     ISR_lock_Context lock_context;
+    status = _TOD_Is_valid_new_time_of_day( tp );
+    if ( status != STATUS_SUCCESSFUL ) {
+      rtems_set_errno_and_return_minus_one( STATUS_GET_POSIX( status ) );
     _TOD_Lock();
     _TOD_Acquire( &lock_context );
       status = _TOD_Set( tp, &lock_context );
diff --git a/cpukit/score/src/coretodadjust.c b/cpukit/score/src/coretodadjust.c
index 90c99803e1..b048aeee71 100644
--- a/cpukit/score/src/coretodadjust.c
+++ b/cpukit/score/src/coretodadjust.c
@@ -42,7 +42,12 @@ Status_Control _TOD_Adjust(
   _TOD_Get( &tod );
   _Timespec_Add_to( &tod, delta );
-  status = _TOD_Set( &tod, &lock_context );
+  status = _TOD_Is_valid_new_time_of_day( &tod );
+  if ( status == STATUS_SUCCESSFUL ) {
+    status = _TOD_Set( &tod, &lock_context );
   _TOD_Unlock();
   return status;
diff --git a/cpukit/score/src/coretodcheck.c b/cpukit/score/src/coretodcheck.c
new file mode 100644
index 0000000000..b42435aa43
--- /dev/null
+++ b/cpukit/score/src/coretodcheck.c
@@ -0,0 +1,59 @@
+ * @file
+ * @ingroup RTEMSScoreTOD
+ * @brief This source file contains the implementation of
+ *   _TOD_Is_valid_new_time_of_day().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/todimpl.h>
+#include <rtems/score/watchdogimpl.h>
+  if ( !_Watchdog_Is_valid_timespec( tod ) ) {
+    return STATUS_INVALID_NUMBER;
+  if ( tod->tv_sec < TOD_SECONDS_1970_THROUGH_1988 ) {
+  if ( _Watchdog_Is_far_future_timespec( tod ) ) {
+  return STATUS_SUCCESSFUL;
diff --git a/cpukit/score/src/coretodset.c b/cpukit/score/src/coretodset.c
index 5fc01215e0..b04242a0da 100644
--- a/cpukit/score/src/coretodset.c
+++ b/cpukit/score/src/coretodset.c
@@ -23,25 +23,6 @@
-static Status_Control _TOD_Check_time_of_day_and_run_hooks(
-  const struct timespec *tod
-  if ( !_Watchdog_Is_valid_timespec( tod ) ) {
-    return STATUS_INVALID_NUMBER;
-  if ( tod->tv_sec < TOD_SECONDS_1970_THROUGH_1988 ) {
-  if ( _Watchdog_Is_far_future_timespec( tod ) ) {
-  return _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
 Status_Control _TOD_Set(
   const struct timespec *tod,
@@ -54,8 +35,9 @@ Status_Control _TOD_Set(
   Status_Control  status;
   _Assert( _TOD_Is_owner() );
+  _Assert( _TOD_Is_valid_new_time_of_day( tod ) == STATUS_SUCCESSFUL );
-  status = _TOD_Check_time_of_day_and_run_hooks( tod );
+  status = _TOD_Hook_Run( TOD_ACTION_SET_CLOCK, tod );
     _TOD_Release( lock_context );
     return status;
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 80fba92483..ee9200aab5 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1390,6 +1390,7 @@ source:
 - cpukit/score/src/coresem.c
 - cpukit/score/src/coretod.c
 - cpukit/score/src/coretodadjust.c
+- cpukit/score/src/coretodcheck.c
 - cpukit/score/src/coretodhookdata.c
 - cpukit/score/src/coretodhookregister.c
 - cpukit/score/src/coretodhookrun.c
2.26.2
