[PATCH] score: Split up rbtreenext.c
Fri Sep 3 14:37:24 UTC 2021
Split up rbtreenext.c since only _RBTree_Minimum() is used by the operating
system core services (thread queues and the EDF scheduler).
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
 cpukit/Makefile.am                |  3 ++
 cpukit/score/src/rbtreemax.c      | 55 +++++++++++++++++++++++++++++++
 cpukit/score/src/rbtreemin.c      | 55 +++++++++++++++++++++++++++++++
 cpukit/score/src/rbtreenext.c     | 48 +++++++++++----------------
 cpukit/score/src/rbtreeprev.c     | 47 ++++++++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml |  3 ++
 6 files changed, 183 insertions(+), 28 deletions(-)
 create mode 100644 cpukit/score/src/rbtreemax.c
 create mode 100644 cpukit/score/src/rbtreemin.c
 create mode 100644 cpukit/score/src/rbtreeprev.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index a883941c9a..35de56615d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -952,8 +952,11 @@ librtemscpu_a_SOURCES += score/src/freechain.c
 librtemscpu_a_SOURCES += score/src/rbtreeextract.c
 librtemscpu_a_SOURCES += score/src/rbtreeinsert.c
 librtemscpu_a_SOURCES += score/src/rbtreeiterate.c
+librtemscpu_a_SOURCES += score/src/rbtreemax.c
+librtemscpu_a_SOURCES += score/src/rbtreemin.c
 librtemscpu_a_SOURCES += score/src/rbtreenext.c
 librtemscpu_a_SOURCES += score/src/rbtreepostorder.c
+librtemscpu_a_SOURCES += score/src/rbtreeprev.c
 librtemscpu_a_SOURCES += score/src/rbtreereplace.c
 librtemscpu_a_SOURCES += score/src/threadallocateunlimited.c
 librtemscpu_a_SOURCES += score/src/thread.c
diff --git a/cpukit/score/src/rbtreemax.c b/cpukit/score/src/rbtreemax.c
new file mode 100644
index 0000000000..1b0e463aa2
--- /dev/null
+++ b/cpukit/score/src/rbtreemax.c
@@ -0,0 +1,55 @@
+ * @file
+ * @ingroup RTEMSScoreRBTree
+ * @brief This source file contains the implementation of
+ *   _RBTree_Maximum().
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/rbtreeimpl.h>
+RBTree_Node *_RBTree_Maximum( const RBTree_Control *tree )
+  RBTree_Node *parent;
+  RBTree_Node *node;
+  parent = NULL;
+  node = _RBTree_Root( tree );
+  while ( node != NULL ) {
+    parent = node;
+    node = _RBTree_Right( node );
+  return parent;
diff --git a/cpukit/score/src/rbtreemin.c b/cpukit/score/src/rbtreemin.c
index 0000000000..b3cd4331c1
--- /dev/null
+++ b/cpukit/score/src/rbtreemin.c
@@ -0,0 +1,55 @@
+ * @file
+ *   _RBTree_Minimum().
+ * are met:
+#endif
+RBTree_Node *_RBTree_Minimum( const RBTree_Control *tree )
+  parent = NULL;
+    parent = node;
+    node = _RBTree_Left( node );
+  return parent;
diff --git a/cpukit/score/src/rbtreenext.c b/cpukit/score/src/rbtreenext.c
index 32087955fe..5d43af0068 100644
--- a/cpukit/score/src/rbtreenext.c
+++ b/cpukit/score/src/rbtreenext.c
@@ -9,17 +9,28 @@
- * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * Copyright (C) 2012 embedded brains GmbH (http://www.embedded-brains.de)
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * are met:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
@@ -29,28 +40,9 @@
-RB_GENERATE_MINMAX( RBTree_Control, RBTree_Node, Node, static )
 RB_GENERATE_NEXT( RBTree_Control, RBTree_Node, Node, static )
-RB_GENERATE_PREV( RBTree_Control, RBTree_Node, Node, static )
-RBTree_Node *_RBTree_Minimum( const RBTree_Control *tree )
-  return RB_MIN( RBTree_Control, RTEMS_DECONST( RBTree_Control *, tree ) );
-RBTree_Node *_RBTree_Maximum( const RBTree_Control *tree )
-  return RB_MAX( RBTree_Control, RTEMS_DECONST( RBTree_Control *, tree ) );
 RBTree_Node *_RBTree_Successor( const RBTree_Node *node )
   return RB_NEXT( RBTree_Control, NULL, RTEMS_DECONST( RBTree_Node *, node ) );
-RBTree_Node *_RBTree_Predecessor( const RBTree_Node *node )
-  return RB_PREV( RBTree_Control, NULL, RTEMS_DECONST( RBTree_Node *, node ) );
diff --git a/cpukit/score/src/rbtreeprev.c b/cpukit/score/src/rbtreeprev.c
index 0000000000..9869cade99
--- /dev/null
+++ b/cpukit/score/src/rbtreeprev.c
@@ -0,0 +1,47 @@
+ * @file
+ *   _RBTree_Predecessor().
+ * are met:
+#endif
+#include <rtems/score/basedefs.h>
+RB_GENERATE_PREV( RBTree_Control, RBTree_Node, Node, static inline )
+RBTree_Node *_RBTree_Predecessor( const RBTree_Node *node )
+  return RB_PREV( RBTree_Control, NULL, RTEMS_DECONST( RBTree_Node *, node ) );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index ee9200aab5..88107b051c 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -1472,8 +1472,11 @@ source:
 - cpukit/score/src/rbtreeextract.c
 - cpukit/score/src/rbtreeinsert.c
 - cpukit/score/src/rbtreeiterate.c
+- cpukit/score/src/rbtreemax.c
+- cpukit/score/src/rbtreemin.c
 - cpukit/score/src/rbtreenext.c
 - cpukit/score/src/rbtreepostorder.c
+- cpukit/score/src/rbtreeprev.c
 - cpukit/score/src/rbtreereplace.c
 - cpukit/score/src/sched.c
 - cpukit/score/src/scheduler.c
2.26.2
