[PATCH RSB] rtems-gcc-10-newlib-head.cfg: Add newlib patch
Joel Sherrill
joel at rtems.org
Fri Sep 3 16:01:24 UTC 2021
On Fri, Sep 3, 2021 at 9:27 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Adds patch to add the -DPREFER_SIZE_OVER_SPEED flag to aarch64 tool
> builds with newlib.
This doesn't explain why. This patch is needed to prevent the use of
the assembly
versions of some methods in newlib which are incorrect for ilp32. This
can be removed
when those methods are updated from ARM. Newlib is quite behind ARM for these
methods and that will require work from an ARM Newlib person.
Updates #4215,
Improve the comment and ensure the ticket is clear that this is temporary for
those reasons.
> rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 3 +++
> 1 file changed, 3 insertions(+)
> diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> index 69c4fb5..3594d1c 100644
> --- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> +++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> @@ -13,6 +13,9 @@
> %patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
> %hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
> +%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch
> +%hash sha512 0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch ad183b6c9a168d1d751505e64873f117c11fb059819d341c5d715619985b285c324ef27c1177c6300088df7bbe3aebd7fa034034c3892f2bf6ec57324c9b1e2a
Looks like you forgot to use sha512-base64
> %define newlib_version 4f81149
> %define newlib_external 1
> %define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
> 1.8.3.1
> devel mailing list
> devel at rtems.org
