[PATCH RSB v2 1/2] rtems-gcc-10-newlib-head.cfg: Add newlib patch
Ryan Long ryan.long at oarcorp.com
Fri Sep 3 17:17:10 UTC 2021
Adds patch to add the -DPREFER_SIZE_OVER_SPEED flag to AArch64 tool
builds with newlib. This forces the generation of AArch64 assembly from
C sources instead of using the hand-optimized code in newlib since it
does not support ILP32. This can be removed when it is fixed upstream.
Updates #4510
 rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
index 69c4fb5..85308c5 100644
--- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
@@ -13,6 +13,9 @@
 %patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
 %hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
+%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch
+%hash sha512 0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch rRg7bJoWjR11FQXmSHPxF8EfsFmBnTQcXXFWGZhbKFwyTvJ8EXfGMACI33u+OuvX+gNANMOJLyv27FcyTJseKg==
 %define newlib_version 4f81149
 %define newlib_external 1
 %define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
1.8.3.1
