[PATCH v1 00/10] Convert and reformat rtems-tools pt. 1
Joel Sherrill
joel at rtems.org
Sat Sep 4 20:30:32 UTC 2021
On Fri, Sep 3, 2021, 9:04 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3/9/21 10:07 pm, Ryan Long wrote:
> > I haven't been building these with clang, so I'll make sure to start
> doing that. I've got a Macbook, so I can test it on there as well.
> This great and thanks. I am amazed how each compiler and version of that
> compiler generates new issues. On the positive side the code is getting
> cleaner.
Fwiw I'm not sure this was clang as much as a difference in how the type
returned by that method was defined. It must not be similar to the other
hosts.
As long as it is fixed, I'm ok.
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210904/bf9adcb3/attachment.html>
