[PATCH 2/2] tester/zynqmp: Limit the restarts to 3
chrisj at rtems.org
chrisj at rtems.org
Sun Sep 5 07:57:54 UTC 2021
tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini | 1 +
1 file changed, 1 insertion(+)
diff --git a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
index c4d091f..dff7d86 100644
--- a/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
+++ b/tester/rtems/testing/bsps/xilinx_zynqmp_lp64_zu3eg.ini
@@ -36,6 +36,7 @@ bsp = xilinx_zynqmp_lp64_zu3eg
arch = aarch64
tester = %{_rtscripts}/tftp.cfg
jobs = 1
+test_restarts = 3
target_reset_regex = ^No ethernet found.*|^BOOTP broadcast 6.*|^.+complete\.+ TIMEOUT.*|^.*Retry count exceeded.*|^.*: No link\..*|^.*TFTP server died; starting again.*
target_start_regex = ^.*Xilinx Zynq MP First Stage Boot Loader.*
requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
2.24.1
