[PATCH RSB] rtems-gcc-10-newlib-head.cfg: Add newlib patch
Tue Sep 7 17:27:27 UTC 2021
On Tue, Sep 7, 2021, 12:18 PM Mr. Andrei Chichak <groups at chichak.ca> wrote:
> Hey Joel,
> I don’t suppose this update will be in the places where the build system
> decides on the instruction set that newlib uses for Cortex-M4????
No. This one is just to patch over a big in some of the aarch64 assembly
language methods in newlib.
I don't know that it does much as a flag except pick the C versions over
assembly language ones.
You'd be better off trying to change the target gcc flags to -Os. I think
Ryan knows how to do that. Chris can answer that also
It is a shame that AFAIK every multilib gets the same optimisation flags
and macros  some of the smaller parts would be better off defaulting to
size over speed.
--joel
> A
> > On 2021-September-07, at 08:56, Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Sep 7, 2021 at 8:04 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> >> Alright, I’ll have that in the next version.
> > I have a patch ready for this and already posted. Just ran out of disk
> space
> > testing it on all architectures on CentOS.
> > When that build finishes, unless someone complains, I will push it.
> > --joel
> >> From: Joel Sherrill <joel at rtems.org>
> >> Sent: Saturday, September 4, 2021 3:31 PM
> >> To: Chris Johns <chrisj at rtems.org>
> >> Cc: Ryan Long <ryan.long at oarcorp.com>; rtems-devel at rtems.org <
> devel at rtems.org>
> >> Subject: Re: [PATCH RSB] rtems-gcc-10-newlib-head.cfg: Add newlib patch
> >> On Fri, Sep 3, 2021, 9:05 PM Chris Johns <chrisj at rtems.org> wrote:
> >> Can we please join onto this an rtems-tools update so the recent fixes
> I pushed
> >> can be picked up?
> >> Ryan can you make that a second patch in this series?
> >> --joel
> >> Thanks
> >> Chris
> >> On 4/9/21 2:40 am, Joel Sherrill wrote:
> >>> You also should add the patch in the gcc-head-newlib-head
> >>> configuration as well for rtems7 tools.
> >>> --joel
> >>> On Fri, Sep 3, 2021 at 11:01 AM Joel Sherrill <joel at rtems.org> wrote:
> >>>> On Fri, Sep 3, 2021 at 9:27 AM Ryan Long <ryan.long at oarcorp.com>
> wrote:
> >>>>> Adds patch to add the -DPREFER_SIZE_OVER_SPEED flag to aarch64 tool
> >>>>> builds with newlib.
> >>>> This doesn't explain why. This patch is needed to prevent the use of
> >>>> the assembly
> >>>> versions of some methods in newlib which are incorrect for ilp32. This
> >>>> can be removed
> >>>> when those methods are updated from ARM. Newlib is quite behind ARM
> for these
> >>>> methods and that will require work from an ARM Newlib person.
> >>>> Updates #4215,
> >>>> Improve the comment and ensure the ticket is clear that this is
> temporary for
> >>>> those reasons.
> >>>>> rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 3 +++
> >>>>> 1 file changed, 3 insertions(+)
> >>>>> diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> >>>>> index 69c4fb5..3594d1c 100644
> >>>>> --- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> >>>>> +++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> >>>>> @@ -13,6 +13,9 @@
> >>>>> %patch add gcc -p1
> https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
> >>>>> %hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch
> afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
> >>>>> +%patch add newlib -p1
> https://devel.rtems.org/raw-attachment/ticket/4510/0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch
> >>>>> +%hash sha512 0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch
> ad183b6c9a168d1d751505e64873f117c11fb059819d341c5d715619985b285c324ef27c1177c6300088df7bbe3aebd7fa034034c3892f2bf6ec57324c9b1e2a
> >>>> Looks like you forgot to use sha512-base64
> >>>>> %define newlib_version 4f81149
> >>>>> %define newlib_external 1
> >>>>> %define newlib_expand_name
> sourceware-mirror-newlib-cygwin-%{newlib_version}
> >>>>> 1.8.3.1
> >>>>> _______________________________________________
> >>>>> devel mailing list
> >>>>> devel at rtems.org
> >>>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210907/9da90570/attachment.html>
