[PATCH RSB v2 2/2] rtems-gcc-head-newlib-head.cfg: Add newlib patch
Gedare Bloom
gedare at rtems.org
Tue Sep 7 18:08:57 UTC 2021
Has this issue been raised with newlib? I didn't see anything on their
ml. The temporary workaround is fine with me.
On Fri, Sep 3, 2021 at 11:17 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Adds patch to add the -DPREFER_SIZE_OVER_SPEED flag to AArch64 tools
> builds with newlib. This forces the generation of AArch64 assembly from
> C sources instead of using the hand-optimized code in newlib since it
> does not support ILP32. This can be removed when it is fixed upstream.
> Updates #4510
> rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 3 +++
> 1 file changed, 3 insertions(+)
> diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> index 4939ca5..c17895b 100644
> --- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> +++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> @@ -12,6 +12,9 @@
> %define newlib_expand_name sourceware-mirror-newlib-cygwin-%{newlib_version}
> %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
> %hash sha512 newlib-%{newlib_version}.tar.gz 9ded46b3077508ef05bbb4bf424777a0baa5aab9c7c0c902fb5529bb73b5b5034c35282e2dbf270cbcd44d84940a20ee270e329db4e4b501046978c18f78a11c
> +%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch
> +%hash sha512 0001-configure.host-Add-DPREFER_SIZE_OVER_SPEED.patch rRg7bJoWjR11FQXmSHPxF8EfsFmBnTQcXXFWGZhbKFwyTvJ8EXfGMACI33u+OuvX+gNANMOJLyv27FcyTJseKg==
> %define with_threads 1
> %define with_plugin 0
> 1.8.3.1
> devel mailing list
> devel at rtems.org
