Does the arm/xilinx-zynqmp BSP work?
Gedare Bloom
gedare at rtems.org
Tue Sep 7 18:19:24 UTC 2021
Hi Chris,
What I understand about the arm/xilinx-zynqmp BSP is that it was made
to run RTEMS paravirtualized under Xen. It drops into aarch32 mode. It
probably can be replaced by the aarch64 version using the ilp32 once
that is stable, and someone can confirm the PV use case works.
Gedare
On Fri, Sep 3, 2021 at 9:51 PM Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> I am testing the console driver with the aarch64/xilinx_zynqmp_lp64_zu3eg BSP
> when I saw the BSP.
> Is this BSP still valid?
> Does this BSP work on real hardware?
> Who is looking after this BSP?
> Chris
> devel mailing list
> devel at rtems.org
