Ticket 4503
zack leung zakthertemsdev at gmail.com
Thu Sep 9 02:17:30 UTC 2021
>Thanks! I guess i'm really unsure about how the pointer relates to the
amount of memory that you can use. I assume the Malloc keeps track of the
sections being used in the heap. Does this function Allocate 2 blocks since
the pointer is set to
(uintptr_t) next_block + HEAP_ALLOC_BONUS - alloc_begin;
>(I know it's a bit naive to assume this given my first question)
think the method is _Heap_Size_of_alloc_area. It may need a wrapper added
to the protected heap wrapper for safety. I don't know if it has one. It
should be the equivalent functionality.
> How would i implement a wrapper and what safety measures need to be
implemented. So far it's checking if :  the block is not in the heap and if
it's been previously used. Is the usable memory in the heap calculated by:
the size of the block * # of blocks?
Thanks, Zack
---------- Forwarded message ---------
Date: Wed, 8 Sept 2021 at 20:30
Subject: Re: Ticket 4503
To: Gedare Bloom <gedare at rtems.org>
Cc: zack leung <zakthertemsdev at gmail.com>, rtems-devel at rtems.org <
devel at rtems.org>
On Wed, Sep 8, 2021 at 11:02 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Zack,
> https://devel.rtems.org/ticket/4503
> The malloc implementation exists in the score as the Heap Manager. search
> for "Heap_" within cpukit to get some ideas where to look.
I think the method is _Heap_Size_of_alloc_area. It may need a wrapper added
newlib's malloc.h will need looking at to make sure we provide the right
methods.
> @Joel are these two tickets duplicates?
> https://devel.rtems.org/ticket/4271
Yes. Closed #4271 and merged comments.
--joel
> -Gedare
> On Tue, Sep 7, 2021 at 7:14 PM zack leung <zakthertemsdev at gmail.com>
> wrote:
>> I was wondering about ticket 4503. I was wondering where The required
>> functionality should be in the underlying score/ capability used can be
>> found to write this function. Also how does this relate  to
>> Add common malloc family extension method malloc_usable_size()
>> <https://devel.rtems.org/ticket/4271>?
>> Thanks
>> Zack
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210909/01601cf5/attachment-0001.html>
