[PATCH rtems-tools v1 02/10] covoar.cc: Convert to C++
Ryan Long ryan.long at oarcorp.com
Thu Sep 9 14:17:47 UTC 2021
ExecutableInfo takes a const char* const parameter and initializes a string. I tried to take off the c_str(), but it wouldn't build then. Is it alright for that to temporarily stay there until I make a sweep through ExecutableInfo.cc? Or do you want me to go ahead and do that, and add it to this patchset?
I was able to remove the c_str() from the CoverageFormatToEnum() call though.
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Chris Johns
Sent: Wednesday, September 8, 2021 5:46 PM
To: devel at rtems.org
Subject: Re: [PATCH rtems-tools v1 02/10] covoar.cc: Convert to C++
On 9/9/21 2:44 am, Ryan Long wrote:
> Got rid of C-strings, changed FILE pointer to ifstream.
>  tester/covoar/covoar.cc | 52
>  1 file changed, 24 insertions(+), 28 deletions(-)
> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc index
> f9d4814..746add1 100644
> --- a/tester/covoar/covoar.cc
> +++ b/tester/covoar/covoar.cc
> @@ -45,11 +45,11 @@ typedef std::list<std::string> CoverageNames;
> typedef std::list<Coverage::ExecutableInfo*> Executables;  typedef
> std::string option_error;
> -bool FileIsReadable( const char *f1 )
> +bool FileIsReadable( const std::string& f1 )
>    struct STAT buf1;
> -  if (STAT( f1, &buf1 ) == -1)
> +  if (STAT( f1.c_str(), &buf1 ) == -1)
>      return false;
>    if (buf1.st_size == 0)
> @@ -177,17 +177,14 @@ int covoar(
>    std::string                   coverageExtension = "cov";
>    Coverage::CoverageFormats_t   coverageFormat = Coverage::COVERAGE_FORMAT_QEMU;
>    Coverage::CoverageReaderBase* coverageReader = NULL;
> -  char*                         executable = NULL;
> -  const char*                   explanations = NULL;
> -  const char*                   gcnosFileName = NULL;
> -  char                          gcnoFileName[FILE_NAME_LENGTH];
> -  char                          gcdaFileName[FILE_NAME_LENGTH];
> -  char                          gcovBashCommand[256];
> +  std::string                   explanations;
> +  std::string                   gcnosFileName;
> +  std::string                   gcnoFileName;
>    std::string                   target;
> -  const char*                   format = "QEMU";
> -  FILE*                         gcnosFile = NULL;
> +  std::string                   format = "QEMU";
> +  std::ifstream                 gcnosFile;
>    Gcov::GcovData*               gcovFile;
> -  const char*                   singleExecutable = NULL;
> +  std::string                   singleExecutable;
>    rld::process::tempfile        objdumpFile( ".dmp" );
>    rld::process::tempfile        err( ".err" );
>    rld::process::tempfile        syms( ".syms" );
> @@ -203,7 +200,6 @@ int covoar(
>    std::string                   outputDirectory = ".";
>    Coverage::DesiredSymbols      symbolsToAnalyze;
>    bool                          branchInfoAvailable = false;
> -  //Target::TargetBase*           targetInfo;
>    // Process command line options.
> @@ -243,7 +239,7 @@ int covoar(
>     * Has path to explanations.txt been specified.
> -  if ( !explanations )
> +  if ( explanations.empty() )
>      throw option_error( "explanations -E" );
> @@ -272,7 +268,7 @@ int covoar(
>    if (verbose) {
> -    if (singleExecutable) {
> +    if (!singleExecutable.empty()) {
>        std::cerr << "Processing a single executable and multiple coverage files"
>                  << std::endl;
>      } else {
> @@ -287,7 +283,7 @@ int covoar(
>      for (const auto& cname : coverageFileNames) {
>        std::cerr << "Coverage file " << cname
>                  << " for executable: " << (*eitr)->getFileName() << std::endl;
> -      if (!singleExecutable)
> +      if (singleExecutable.empty())
>          eitr++;
> @@ -309,7 +305,7 @@ int covoar(
>    // If a single executable was specified, process the remaining
>    // arguments as coverage file names.
>      // Ensure that the executable is readable.
>      if (!FileIsReadable( singleExecutable )) { @@ -332,14 +328,14 @@
> int covoar(
>        if (!coverageFileNames.empty()) {
>          if ( !dynamicLibrary.empty() ) {
>            executableInfo = new Coverage::ExecutableInfo(
> -            singleExecutable,
> +            singleExecutable.c_str(),
>              dynamicLibrary,
>              verbose,
>              symbolsToAnalyze
>          } else {
> -            singleExecutable,
Can ExecutableInfo take std::string& ?
>              verbose,
>              symbolsToAnalyze
> @@ -393,11 +389,11 @@ int covoar(
>                << " symbols" << std::endl;
>    // Create explanations.
> -  if ( explanations )
> -    allExplanations.load( explanations );
> +  if ( !explanations.empty() )
> +    allExplanations.load( explanations.c_str() );
>    // Create coverage map reader.
> -  coverageFormat = Coverage::CoverageFormatToEnum(format);
> +  coverageFormat = Coverage::CoverageFormatToEnum(format.c_str());
And here.
>    coverageReader = Coverage::CreateCoverageReader(coverageFormat);
>    if (!coverageReader)
>      throw rld::error( "Unable to create coverage file reader",
> "covoar" ); @@ -441,7 +437,7 @@ int covoar(
>      // DEBUG Print ExecutableInfo content
>      //exe->dumpExecutableInfo();
> -    if (!singleExecutable) {
> +    if (singleExecutable.empty()) {
>        eitr++;
> @@ -455,18 +451,18 @@ int covoar(
>    // Generate Gcov reports
> -  if (gcnosFileName) {
> +  if (!gcnosFileName.empty()) {
>      if (verbose)
>        std::cerr << "Generating Gcov reports..." << std::endl;
> -    gcnosFile = fopen ( gcnosFileName , "r" );
> +    gcnosFile.open( gcnosFileName );
>      if ( !gcnosFile )
>        std::cerr << "Unable to open " << gcnosFileName << std::endl;
>      else {
> -      while ( fscanf( gcnosFile, "%s", inputBuffer ) != EOF) {
> +      while ( gcnosFile >> inputBuffer ) {
>          gcovFile = new Gcov::GcovData( symbolsToAnalyze );
> -        strcpy( gcnoFileName, inputBuffer );
> +        gcnoFileName = inputBuffer;
>          if ( verbose )
>            std::cerr << "Processing file: " << gcnoFileName <<
> std::endl; @@ -481,7 +477,7 @@ int covoar(
>          delete gcovFile;
> -      fclose( gcnosFile );
> +      gcnosFile.close();
> @@ -525,7 +521,7 @@ int covoar(
>    // Write explanations that were not found.
> -  if ( explanations ) {
> +  if ( !explanations.empty() ) {
>      std::string notFound;
>      notFound = outputDirectory;
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
