Subject: [PATCH] improve the format error reporting on i386
Gedare Bloom
gedare at rtems.org
Fri Sep 10 14:20:28 UTC 2021
Hi Zack,
Use git-rebase --interactive option, and reword the commit message.
The email comes through with an additional subject line, I'm not sure
if that is intended. You don't need to repeat the first line of the
commit message. It seems like the commit message you have used is:
score/i386: improve the format of exception reporting
Updates #4203."Updates #4203."
You should modify that commit message, and regenerate the patch/email.
-Gedare
On Fri, Sep 10, 2021 at 7:07 AM zack leung <zakthertemsdev at gmail.com> wrote:
> Where are the duplicates been trying to fix the commit messages?
> Thanks zack
> Il gio 9 set 2021, 22:30 Gedare Bloom <gedare at rtems.org> ha scritto:
>> Hi Zack,
>> It looks like something got a little messed up with your commit
>> message. Please see if you can fix it to remove the duplication(s).
>> On Thu, Sep 9, 2021 at 6:00 PM zack leung <zakthertemsdev at gmail.com> wrote:
>> > cpukit/score/cpu/i386/cpu.c | 2 +-
>> > 1 file changed, 1 insertion(+), 1 deletion(-)
>> > diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
>> > index 77b7a7161c..06af57418d 100644
>> > --- a/cpukit/score/cpu/i386/cpu.c
>> > +++ b/cpukit/score/cpu/i386/cpu.c
>> > @@ -215,7 +215,7 @@ void _CPU_Exception_frame_print (const CPU_Exception_frame *ctx)
>> > unsigned int faultAddr = 0;
>> > printk("----------------------------------------------------------\n");
>> > - printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %" PRId32 "\n",
>> > + printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %" PRIx32 "\n",
>> > ctx->idtIndex,
>> > ctx->eip,
>> > _Thread_Executing->Object.id);
>> > 2.33.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
