[PATCH rtems-tools v2 01/10] CoverageWriter: Convert to C++
Ryan Long ryan.long at oarcorp.com
Fri Sep 10 18:03:06 UTC 2021
 tester/covoar/CoverageWriterBase.h    |  4 +++-
 tester/covoar/CoverageWriterRTEMS.cc  | 26 +++++++++++++----------
 tester/covoar/CoverageWriterRTEMS.h   |  4 +++-
 tester/covoar/CoverageWriterSkyeye.cc | 39 +++++++++++++++++++----------------
 tester/covoar/CoverageWriterSkyeye.h  |  4 +++-
 tester/covoar/CoverageWriterTSIM.cc   | 23 ++++++++++-----------
 tester/covoar/CoverageWriterTSIM.h    |  4 +++-
 7 files changed, 59 insertions(+), 45 deletions(-)
diff --git a/tester/covoar/CoverageWriterBase.h b/tester/covoar/CoverageWriterBase.h
index e43a45b..fca501a 100644
--- a/tester/covoar/CoverageWriterBase.h
+++ b/tester/covoar/CoverageWriterBase.h
@@ -9,6 +9,8 @@
 #include <stdint.h>
+#include <string>
 #include "CoverageMapBase.h"
 namespace Coverage {
@@ -46,7 +48,7 @@ namespace Coverage {
      *  @return Returns TRUE if the method succeeded and FALSE if it failed.
     virtual void writeFile(
-      const char* const file,
+      const std::string& file,
       CoverageMapBase*  coverage,
       uint32_t          lowAddress,
       uint32_t          highAddress
diff --git a/tester/covoar/CoverageWriterRTEMS.cc b/tester/covoar/CoverageWriterRTEMS.cc
index 48e8fd1..fc8a241 100644
--- a/tester/covoar/CoverageWriterRTEMS.cc
+++ b/tester/covoar/CoverageWriterRTEMS.cc
@@ -10,6 +10,7 @@
 #include <iostream>
+#include <fstream>
 #include <iomanip>
 #include <rld.h>
@@ -28,23 +29,23 @@ namespace Coverage {
   void CoverageWriterRTEMS::writeFile(
-    FILE*                       coverageFile;
+    std::ofstream               coverageFile;
     uint32_t                    a;
-    int                         status;
     uint8_t                     cover;
     rtems_coverage_map_header_t header;
+    std::ofstream::pos_type     bytes_before;
      *  read the file and update the coverage map passed in
-    coverageFile = ::fopen( file, "w" );
-    if ( !coverageFile ) {
+    coverageFile.open( file );
+    if ( !coverageFile.is_open() ) {
       std::ostringstream what;
       what << "Unable to open " << file;
       throw rld::error( what, "CoverageWriterRTEMS::writeFile" );
@@ -58,9 +59,10 @@ namespace Coverage {
     header.end           = highAddress;
     strcpy( header.desc, "RTEMS Coverage Data" );
-    status = ::fwrite(&header, 1, sizeof(header), coverageFile);
-    if (status != sizeof(header)) {
-      ::fclose( coverageFile );
+    bytes_before = coverageFile.tellp();
+    coverageFile.write( (char *) &header, sizeof( header ) );
+    if ( coverageFile.tellp() - bytes_before != sizeof( header ) ) {
       what << "Unable to write header to " << file;
@@ -68,8 +70,11 @@ namespace Coverage {
     for ( a=lowAddress ; a < highAddress ; a++ ) {
       cover  = ((coverage->wasExecuted( a ))     ? 0x01 : 0);
-      status = fwrite(&cover, 1, sizeof(cover), coverageFile);
-      if (status != sizeof(cover)) {
+      coverageFile.write( (char *) &cover, sizeof( cover ) );
+      if ( coverageFile.tellp() - bytes_before != sizeof( cover ) ) {
         std::cerr << "CoverageWriterRTEMS::writeFile - write to "
                   << file
                   << " at address 0x%"
@@ -81,6 +86,5 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageWriterRTEMS.h b/tester/covoar/CoverageWriterRTEMS.h
index b66d2fa..c760936 100644
--- a/tester/covoar/CoverageWriterRTEMS.h
+++ b/tester/covoar/CoverageWriterRTEMS.h
@@ -7,6 +7,8 @@
 #ifndef __COVERAGE_WRITER_RTEMS_H__
 #define __COVERAGE_WRITER_RTEMS_H__
+#include <string>
 #include "CoverageWriterBase.h"
@@ -33,7 +35,7 @@ namespace Coverage {
     /* Inherit documentation from base class. */
     void writeFile(
diff --git a/tester/covoar/CoverageWriterSkyeye.cc b/tester/covoar/CoverageWriterSkyeye.cc
index 7f78644..fcc7052 100644
--- a/tester/covoar/CoverageWriterSkyeye.cc
+++ b/tester/covoar/CoverageWriterSkyeye.cc
@@ -12,6 +12,7 @@
 #include <iostream>
+#include <fstream>
 #include <iomanip>
 #include <rld.h>
@@ -30,23 +31,23 @@ namespace Coverage {
   void CoverageWriterSkyeye::writeFile(
-    CoverageMapBase*  coverage,
-    uint32_t          lowAddress,
-    uint32_t          highAddress
+    CoverageMapBase*    coverage,
+    uint32_t            lowAddress,
+    uint32_t            highAddress
-    uint32_t      a;
-    uint8_t       cover;
-    prof_header_t header;
-    int           status;
+    uint32_t                a;
+    uint8_t                 cover;
+    prof_header_t           header;
       throw rld::error( what, "CoverageWriterSkyeye::writeFile" );
@@ -60,9 +61,10 @@ namespace Coverage {
     header.prof_end      = highAddress;
     strcpy( header.desc, "Skyeye Coverage Data" );
@@ -71,9 +73,11 @@ namespace Coverage {
     for ( a = lowAddress; a < highAddress; a += 8 ) {
       cover |= ((coverage->wasExecuted( a + 4 )) ? 0x10 : 0);
         what << "write to " << file
              << " at address 0x"
@@ -85,6 +89,5 @@ namespace Coverage {
diff --git a/tester/covoar/CoverageWriterSkyeye.h b/tester/covoar/CoverageWriterSkyeye.h
index 8a74f55..8f11959 100644
--- a/tester/covoar/CoverageWriterSkyeye.h
+++ b/tester/covoar/CoverageWriterSkyeye.h
@@ -7,6 +7,8 @@
 #ifndef __COVERAGE_WRITER_Skyeye_H__
 #define __COVERAGE_WRITER_Skyeye_H__
+#include <string>
     void writeFile(
diff --git a/tester/covoar/CoverageWriterTSIM.cc b/tester/covoar/CoverageWriterTSIM.cc
index 62a1f7d..9ec12e4 100644
--- a/tester/covoar/CoverageWriterTSIM.cc
+++ b/tester/covoar/CoverageWriterTSIM.cc
@@ -9,6 +9,7 @@
 #include <iostream>
+#include <fstream>
 #include <iomanip>
 #include <rld.h>
@@ -27,7 +28,7 @@ namespace Coverage {
   void CoverageWriterTSIM::writeFile(
@@ -35,30 +36,29 @@ namespace Coverage {
     uint32_t a;
     int      cover;
     int      i;
-    int      status;
       throw rld::error( what, "CoverageWriterTSIM::writeFile" );
     for ( a = lowAddress; a < highAddress; a += 0x80 ) {
-      status = fprintf( coverageFile, "%x : ", a );
-      if ( status == EOF || status == 0 ) {
+      coverageFile << std::hex << a << " : " << std::dec;
+      if ( coverageFile.fail() ) {
         break;
       for ( i = 0; i < 0x80; i += 4 ) {
         cover = ((coverage->wasExecuted( a + i )) ? 1 : 0);
-        status = ::fprintf( coverageFile, "%d ", cover );
+        coverageFile << cover << " ";
                << " at address 0x"
@@ -69,9 +69,8 @@ namespace Coverage {
-      ::fprintf( coverageFile, "\n" );
+      coverageFile << std::endl;
diff --git a/tester/covoar/CoverageWriterTSIM.h b/tester/covoar/CoverageWriterTSIM.h
index b43e1c6..5ae57f8 100644
--- a/tester/covoar/CoverageWriterTSIM.h
+++ b/tester/covoar/CoverageWriterTSIM.h
@@ -7,6 +7,8 @@
 #ifndef __COVERAGE_WRITER_TSIM_H__
 #define __COVERAGE_WRITER_TSIM_H__
+#include <string>
     void writeFile(
1.8.3.1
