[PATCH rtems-tools v2 02/10] covoar.cc: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Fri Sep 10 18:03:07 UTC 2021
Got rid of C-strings, changed FILE pointer to ifstream.
tester/covoar/covoar.cc | 50 +++++++++++++++++++++++--------------------------
1 file changed, 23 insertions(+), 27 deletions(-)
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index f9d4814..710294b 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -45,11 +45,11 @@ typedef std::list<std::string> CoverageNames;
typedef std::list<Coverage::ExecutableInfo*> Executables;
typedef std::string option_error;
-bool FileIsReadable( const char *f1 )
+bool FileIsReadable( const std::string& f1 )
struct STAT buf1;
- if (STAT( f1, &buf1 ) == -1)
+ if (STAT( f1.c_str(), &buf1 ) == -1)
return false;
if (buf1.st_size == 0)
@@ -177,17 +177,14 @@ int covoar(
std::string coverageExtension = "cov";
Coverage::CoverageFormats_t coverageFormat = Coverage::COVERAGE_FORMAT_QEMU;
Coverage::CoverageReaderBase* coverageReader = NULL;
- char* executable = NULL;
- const char* explanations = NULL;
- const char* gcnosFileName = NULL;
- char gcnoFileName[FILE_NAME_LENGTH];
- char gcdaFileName[FILE_NAME_LENGTH];
- char gcovBashCommand[256];
+ std::string explanations;
+ std::string gcnosFileName;
+ std::string gcnoFileName;
std::string target;
- const char* format = "QEMU";
- FILE* gcnosFile = NULL;
+ std::string format = "QEMU";
+ std::ifstream gcnosFile;
Gcov::GcovData* gcovFile;
- const char* singleExecutable = NULL;
+ std::string singleExecutable;
rld::process::tempfile objdumpFile( ".dmp" );
rld::process::tempfile err( ".err" );
rld::process::tempfile syms( ".syms" );
@@ -203,7 +200,6 @@ int covoar(
std::string outputDirectory = ".";
Coverage::DesiredSymbols symbolsToAnalyze;
bool branchInfoAvailable = false;
- //Target::TargetBase* targetInfo;
// Process command line options.
@@ -243,7 +239,7 @@ int covoar(
* Has path to explanations.txt been specified.
- if ( !explanations )
+ if ( explanations.empty() )
throw option_error( "explanations -E" );
@@ -272,7 +268,7 @@ int covoar(
if (verbose) {
- if (singleExecutable) {
+ if (!singleExecutable.empty()) {
std::cerr << "Processing a single executable and multiple coverage files"
<< std::endl;
} else {
@@ -287,7 +283,7 @@ int covoar(
for (const auto& cname : coverageFileNames) {
std::cerr << "Coverage file " << cname
<< " for executable: " << (*eitr)->getFileName() << std::endl;
- if (!singleExecutable)
+ if (singleExecutable.empty())
eitr++;
@@ -309,7 +305,7 @@ int covoar(
// If a single executable was specified, process the remaining
// arguments as coverage file names.
// Ensure that the executable is readable.
if (!FileIsReadable( singleExecutable )) {
@@ -332,14 +328,14 @@ int covoar(
if (!coverageFileNames.empty()) {
if ( !dynamicLibrary.empty() ) {
executableInfo = new Coverage::ExecutableInfo(
- singleExecutable,
+ singleExecutable.c_str(),
dynamicLibrary,
verbose,
symbolsToAnalyze
} else {
- singleExecutable,
verbose,
symbolsToAnalyze
@@ -393,8 +389,8 @@ int covoar(
<< " symbols" << std::endl;
// Create explanations.
- if ( explanations )
- allExplanations.load( explanations );
+ if ( !explanations.empty() )
+ allExplanations.load( explanations.c_str() );
// Create coverage map reader.
coverageFormat = Coverage::CoverageFormatToEnum(format);
@@ -441,7 +437,7 @@ int covoar(
// DEBUG Print ExecutableInfo content
//exe->dumpExecutableInfo();
- if (!singleExecutable) {
+ if (singleExecutable.empty()) {
eitr++;
@@ -455,18 +451,18 @@ int covoar(
// Generate Gcov reports
- if (gcnosFileName) {
+ if (!gcnosFileName.empty()) {
if (verbose)
std::cerr << "Generating Gcov reports..." << std::endl;
- gcnosFile = fopen ( gcnosFileName , "r" );
+ gcnosFile.open( gcnosFileName );
if ( !gcnosFile )
std::cerr << "Unable to open " << gcnosFileName << std::endl;
else {
- while ( fscanf( gcnosFile, "%s", inputBuffer ) != EOF) {
+ while ( gcnosFile >> inputBuffer ) {
gcovFile = new Gcov::GcovData( symbolsToAnalyze );
- strcpy( gcnoFileName, inputBuffer );
+ gcnoFileName = inputBuffer;
if ( verbose )
std::cerr << "Processing file: " << gcnoFileName << std::endl;
@@ -481,7 +477,7 @@ int covoar(
delete gcovFile;
- fclose( gcnosFile );
+ gcnosFile.close();
@@ -525,7 +521,7 @@ int covoar(
// Write explanations that were not found.
- if ( explanations ) {
+ if ( !explanations.empty() ) {
std::string notFound;
notFound = outputDirectory;
1.8.3.1
