[PATCH] eng: Add register block specification types
Sebastian Huber
Mon Sep 13 06:27:04 UTC 2021
On 11/09/2021 19:59, Joel Sherrill wrote:
> On Fri, Sep 10, 2021, 9:41 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> A register block may be used to specify the memory-mapped interface to
> the hardware. Register blocks consist of register block members.
> Register block members are either instances of registers or instances of
> other register blocks. Registers consists of bit fields.
> I hope you don't mean C bit fields. They are quite non-portable.
This register block specification is independent of an interface in a
particular programming language. It is similar to a machine readable
manual. From the register block specification you could generate code
for C, C++, Rust, Ada, Python, and so on. Currently, there is only a C
header file generator (which doesn't use C bit fields), for example:
https://git.rtems.org/sebh/rtems.git/tree/bsps/include/grlib/gptimer-regs.h?h=qual-35
> And I hope we are avoiding packed in this definition of requirements set.
What do you mean with "packed"?
> Unfortunately it seems there are more things you can get wrong here
> which leads to negative requirements and negative requirements are bad
Sorry, what do you mean with "negative requirements" here?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
