[PATCH] eng: Add register block specification types
Sebastian Huber
Mon Sep 13 06:38:44 UTC 2021
On 12/09/2021 03:32, Chris Johns wrote:
> On 11/9/21 12:41 am, Sebastian Huber wrote:
>> A register block may be used to specify the memory-mapped interface to
>> the hardware. Register blocks consist of register block members.
>> Register block members are either instances of registers or instances of
>> other register blocks. Registers consists of bit fields.
> I feel this is for generation of headers of devices for drivers. Is this correct?
Yes, see for example:
https://git.rtems.org/sebh/rtems.git/tree/bsps/include/grlib/gptimer-regs.h?h=qual-35
> What bus interface API you are considering mapping this specification too?
Since we don't have a bus interface API in RTEMS I used something simple:
https://git.rtems.org/sebh/rtems.git/tree/bsps/sparc/include/grlib/io.h?h=qual-35
> I do not know the purpose of this addition and the long term effect of this
> being formalised like this.
The purpose is a machine readable specification of the hardware
interfaces in terms of register blocks, registers, and bit fields.
I used a similar approach to generate the header files for the AArch32
and AArch64 system registers:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/include/rtems/score/aarch32-system-registers.h
https://git.rtems.org/rtems/tree/cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h
This approach is not limited to memory mapped register blocks.
A machine readable hardware interface specification gives you a lot of
flexibility. The labor intensive work is the first step, from a hand
written manual to the specification items. If you have a better format
in the future, it would be easy to convert the files with a small Python
script.
>> Update #3715.
> I could not see this topic in the list for that ticket. I prefer that list stays
> as it is.
This register block specification format specification belongs to
"Definition of data model and format actually used for the project".
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
