[PATCH] c-user: Define lower and higher priority
Sebastian Huber
Tue Sep 14 14:04:10 UTC 2021
c-user/glossary.rst | 22 ++++++++++++++++++++++
1 file changed, 22 insertions(+)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 16a8b8d..b0cf7df 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -398,6 +398,17 @@ Glossary
heterogeneous
A multiprocessor computer system composed of dissimilar processors.
+ higher priority
+ A :term:`task` ``H`` has a higher priority than a task ``L``, if task ``H``
+ is more important that task ``L``. For example, priority based schedulers
+ will only allocate processors to the highest priority tasks. In
+ :term:`RTEMS`, task priorities are represented by non-negative integers.
+ For the Classic :term:`API`, if a numerical priority value ``R`` is less
+ than a numerical priority value ``S``, then ``R`` expresses a higher priority
+ than ``S``. For the :term:`POSIX` API, if a numerical priority value ``P``
+ is greater than a numerical priority value ``Q``, then ``P`` expresses a
+ higher priority than ``Q``.
home scheduler
The home scheduler of a :term:`task` is a :term:`scheduler` which is an
:term:`eligible scheduler` and which is assigned to the task during its
@@ -498,6 +509,17 @@ Glossary
A multiprocessor configuration where shared memory is not used for
communication.
+ lower priority
+ A :term:`task` ``L`` has a lower priority than a task ``H``, if task ``L``
+ is less important that task ``H``. For example, priority based schedulers
+ For the Classic :term:`API`, if a numerical priority value ``R`` is greater
+ than a numerical priority value ``S``, then ``R`` expresses a lower priority
+ is less than a numerical priority value ``Q``, then ``P`` expresses a lower
+ priority than ``Q``.
major number
The index of a device driver in the Device Driver Table.
2.31.1
