[PATCH] eng: Add register block specification types
Chris Johns
chrisj at rtems.org
Tue Sep 14 22:48:51 UTC 2021
On 14/9/21 8:08 pm, Sebastian Huber wrote:
> On 10/09/2021 16:41, Sebastian Huber wrote:
>> A register block may be used to specify the memory-mapped interface to
>> the hardware. Register blocks consist of register block members.
>> Register block members are either instances of registers or instances of
>> other register blocks. Registers consists of bit fields.
>> Update #3715.
> Any objections to integrate this?
I am sorry but in it's current form I do.
> The hardware specification is work in
> progress. What I have currently is a proof of concept for the GR740 and the
> GR712RC. It should cause no harm to have it documented. If this stuff is
> generally useful is an open question.
Who fixes the spec for the other bus models? Will those fixes be compatible and
if not who fixes the existing specs or drivers?
Those questions expose the liability the project is left with. For me to make
changes and look after the GR740 and GR712RC it would be a lot of work because I
have not worked with those devices and they are important to some users.
I do not see the value in us hosting a custom or subset solution for a model to
access hardware we should not be encouraging. I see value in a solution that can
support all bus solutions.
