[PATCH v4] improve the format of error reporting on i386
Gedare Bloom
gedare at rtems.org
Wed Sep 15 15:18:11 UTC 2021
On Mon, Sep 13, 2021 at 6:10 PM zack leung <zakthertemsdev at gmail.com> wrote:
> Gedare told me just to change the ID when I submitted the other I sent you
> in discord. Sorry for things bouncing back and forth.
I said not to change the `type` of the register context variables from
32 to ptr. You can change their representation to hex that's fine by
me, with the fixed width and 0x prepended.
> On Mon, 13 Sept 2021 at 23:44, Joel Sherrill <joel at rtems.org> wrote:
> > On Sun, Sep 12, 2021 at 7:02 PM zack leung <zakthertemsdev at gmail.com>
> > wrote:
> > > Thread id is now a Hex value.
> > > Updates #4203
> > > cpukit/score/cpu/i386/cpu.c | 2 +-
> > > 1 file changed, 1 insertion(+), 1 deletion(-)
> > > diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
> > > index 77b7a7161c..06af57418d 100644
> > > --- a/cpukit/score/cpu/i386/cpu.c
> > > +++ b/cpukit/score/cpu/i386/cpu.c
> > > @@ -215,7 +215,7 @@ void _CPU_Exception_frame_print (const
> > > CPU_Exception_frame *ctx)
> > > unsigned int faultAddr = 0;
> > > printk("----------------------------------------------------------\n");
> > > - printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
> > > PRId32 "\n",
> > > + printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
> > > PRIx32 "\n",
> > PC and ID should use .... PC 0x%08" PRIx32.
> > Prefixing with 0x to indicate that the number is hexadecimal. Printing
> > it with leading zero's and 8 digits wide helps since the address and
> > thread id are 32-bit (8 nibbles). A thread id is usually printed like
> > 0x0a010004
> > Does this patch have all your other changes? I've slept since seeing
> > this time and thought there were changes..
> > --joel
> > > ctx->idtIndex,
> > > ctx->eip,
> > > _Thread_Executing->Object.id);
> > > 2.33.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
