[PATCH v2] c-user: Define lower and higher priority
Sebastian Huber
Wed Sep 15 15:44:10 UTC 2021
On 15/09/2021 17:22, Gedare Bloom wrote:
>> priority
>> The priority is a mechanism used to represent the relative importance of an
>> - element in a set of items. RTEMS uses :term:`task priorities <task priority>` to determine
>> - which :term:`task` should execute.
>> + element in a set of items.
>> + For example, :term:`RTEMS` uses :term:`task priorities <task priority>` to determine which
>> + :term:`task` should execute on a processor. In RTEMS, priorities are
>> + represented by non-negative integers.
>> + For the Classic :term:`API`, if a numerical priority value ``A`` is greater
>> + than a numerical priority value ``B``, then ``A`` expresses a
>> + :term:`higher priority` than ``B``. If a numerical priority value ``C`` is
>> + less than a numerical priority value ``D``, then ``C`` expresses a
>> + :term:`lower priority` than ``D``.
>> + For the :term:`POSIX` API, if a numerical priority value ``R`` is less than
>> + a numerical priority value ``S``, then ``R`` expresses a lower priority than
>> + ``S``. If a numerical priority value ``T`` is greater than a numerical
>> + priority value ``U``, then ``T`` expresses a higher priority than ``U``.
> These are backwards. Classic priorities with numerically greater
> values indicate lower priorities. POSIX priorities with numerically
> higher values express higher priorities.
Thanks for noticing this. I swapped the lower and higher priority items:
https://git.rtems.org/rtems-central/commit/?id=4cd035ab1160394172d2669dd2ac22668b365991
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
