RSB
Wed Sep 15 15:46:21 UTC 2021
On Tue, Sep 14, 2021 at 5:52 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/9/21 4:49 am, Joel Sherrill wrote:
> > On Mon, Sep 13, 2021, 7:02 PM Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> >     On Mon, Sep 13, 2021 at 6:54 PM Chris Johns <chrisj at rtems.org
> >     <mailto:chrisj at rtems.org>> wrote:
> >     > On 13/9/21 11:20 pm, Joel Sherrill wrote:
> >     > > Hi
> >     > > If building a bset tar file, does it matter if the installation prefix
> >     > > is writable?
> >     > > ../source-builder/sb-set-builder --bset-tar-file --log=l-i386.txt
> >     > > --prefix=/rtems/tools 5/rtems-i386
> >     > > RTEMS Source Builder - Set Builder, 5 (c7870f6e6199)
> >     > > error: prefix is not writable: /rtems/tools
> >     > > It does if you are planning to immediately install but if building for
> >     > > later installation, I don't think it matters.
> >     > > Thoughts?
> >     > What happens if you add --no-install?
> >     It skips the test.
> > And doesn't install anything.
> Excellent.
> >     > If this does help the question moves to if making a bset is packaging
> >     around an
> >     > install or is it the only output option?
> >     With a bset-tar, I don't think it did an install anyway. But it's been
> >     a long day. I can
> >     check again tomorrow if you want me to.
> > Builds and installs tools unless you specify no install.
> > Tar files is an additive behavior.
> OK and thanks
> > I am off today but will try to review the help and user docs to make sure this
> > is clear.
> > Any thoughts on the tools tarballs not having the architecture name in it? If
> > you build multiple architectures or just want to maintain tool tarballs for
> > multiple architectures, you have to manually rename them.
> Could you please remind me about the naming and then what you would like?
After building tools for ARM for RTEMS 5, this is what is in the tar/
directory.
+ ls -1 tar
automake-1.12.6-x86_64-linux-gnu-1.tar.bz2
rtems-tools-0a5d2057749066e7d184836e92c7ce5334fccc90-1.tar.bz2
I wondered where autoconf was and it is in the automake tarball. Either
autoconf should be in a separate tarball of the tarfile should be autotools
like is used in the bsets. Not sure which but just saying automake-1.12.6
and including autoconf is not right.
The issue I mentioned is that the same rtems-tools- at TAG@-1.tar.bz2
is used for every architecture. Perhaps rtems-tools- at ARCH@- at TAG@-1.tar.bz2.
Then you can script building all architectures without renaming files.
One thing I also noticed which might cause problems with people feeding
the tools tarball into another packaging system is that there are duplicate
files across architectures. I don't see the RSB addressing this but someone
creating RPM, deb, etc packages might have to. If post processing
is needed to break out a rtems-tools-common tarball, that is on someone
feeding these into something that doesn't like duplicate files in packages.
So.. (1) automake has autoconf also and (2) same name is used for rtems-tools
independent of architecture.
--joel
> Thanks
> Chris
