[PATCH v4] improve the format of error reporting on i386
Thu Sep 16 14:56:20 UTC 2021
Hi Zack,
Although we are not currently filtering HTML on this mailing list, it
is strongly preferred that you would send plaintext email when there's
no need for the HTML features. We may disable/filter HTML in the
future, as is now done for users at rtems.org
This email could have been as easily sent in plaintext. Make sure
anything that is PRIx32 has a 0x prepended to it.
Thanks,
Gedare
On Wed, Sep 15, 2021 at 6:26 PM zack leung <zakthertemsdev at gmail.com> wrote:
> printk("----------------------------------------------------------\n");
> printk("Exception %" PRIu32 " caught at PC 0x%" PRIx32 " by thread 0x%" PRIx32 "\n",
> ctx->idtIndex,
> ctx->eip,
> _Thread_Executing->Object.id);
> printk("Processor execution context at time of the fault was :\n");
> printk(" EAX = %" PRIx32 " EBX = 0x%" PRIx32 " ECX = %" PRIx32 " EDX = %" PRIx32 "\n",
> ctx->eax, ctx->ebx, ctx->ecx, ctx->edx);
> printk(" ESI = 0x%" PRIx32 " EDI = 0x%" PRIx32 " EBP = 0x%" PRIx32 " ESP = 0x%" PRIx32 "\n",
> ctx->esi, ctx->edi, ctx->ebp, ctx->esp0);
> Before I send my patch here is what i'll change . So i can do this for example format the hex values with 0x and
> have the thread id as a hex value.
> On Wed, 15 Sept 2021 at 15:18, Gedare Bloom <gedare at rtems.org> wrote:
>> On Mon, Sep 13, 2021 at 6:10 PM zack leung <zakthertemsdev at gmail.com> wrote:
>> > Gedare told me just to change the ID when I submitted the other I sent you
>> > in discord. Sorry for things bouncing back and forth.
>> I said not to change the `type` of the register context variables from
>> 32 to ptr. You can change their representation to hex that's fine by
>> me, with the fixed width and 0x prepended.
>> > On Mon, 13 Sept 2021 at 23:44, Joel Sherrill <joel at rtems.org> wrote:
>> > > On Sun, Sep 12, 2021 at 7:02 PM zack leung <zakthertemsdev at gmail.com>
>> > > wrote:
>> > > > Thread id is now a Hex value.
>> > > > Updates #4203
>> > > > cpukit/score/cpu/i386/cpu.c | 2 +-
>> > > > 1 file changed, 1 insertion(+), 1 deletion(-)
>> > > > diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
>> > > > index 77b7a7161c..06af57418d 100644
>> > > > --- a/cpukit/score/cpu/i386/cpu.c
>> > > > +++ b/cpukit/score/cpu/i386/cpu.c
>> > > > @@ -215,7 +215,7 @@ void _CPU_Exception_frame_print (const
>> > > > CPU_Exception_frame *ctx)
>> > > > unsigned int faultAddr = 0;
>> > > > - printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
>> > > > PRId32 "\n",
>> > > > + printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
>> > > > PRIx32 "\n",
>> > > PC and ID should use .... PC 0x%08" PRIx32.
>> > > Prefixing with 0x to indicate that the number is hexadecimal. Printing
>> > > it with leading zero's and 8 digits wide helps since the address and
>> > > thread id are 32-bit (8 nibbles).  A thread id is usually printed like
>> > > 0x0a010004
>> > > Does this patch have all your other changes? I've slept since seeing
>> > > this time and thought there were changes..
>> > > --joel
>> > > > ctx->idtIndex,
>> > > > ctx->eip,
>> > > > 2.33.0
>> > > > _______________________________________________
>> > > > devel mailing list
>> > > > devel at rtems.org
>> > > > http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
