[PATCH RSB v2] Remove automake/autoconf from rtems 6 tools
Joel Sherrill
joel at rtems.org
Thu Sep 16 17:43:45 UTC 2021
On Thu, Sep 16, 2021 at 10:01 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Sep 16, 2021 at 8:56 AM Joel Sherrill <joel at rtems.org> wrote:
> > These are unneeded with the waf build system.
> > Closes #4081.
> > bare/config/devel/autotools-base.bset | 9 ---------
> > bare/config/devel/autotools-internal.bset | 13 -------------
> > bare/config/devel/autotools.bset | 14 --------------
> Not these.
Sorry. Misunderstood.
> > rtems/config/6/rtems-autotools-base.bset | 9 ---------
> > rtems/config/6/rtems-autotools-internal.bset | 11 -----------
> > rtems/config/6/rtems-autotools.bset | 25 -------------------------
> > rtems/config/6/rtems-default.bset | 2 --
> > rtems/config/6/rtems-microblaze.bset | 2 --
> Just these. The rtems-autotools* ones :)
> > rtems/config/tools/rtems-autoconf-2.69-1.cfg | 23 -----------------------
> > rtems/config/tools/rtems-automake-1.12.6-1.cfg | 23 -----------------------
> I don't think these can be removed either, I think they're used for
> the gcc-cross build.
I'll leave them but they sound incorrectly named going forward. They will
no longer be "rtems-auto*" -- just auto* required to build something else.
> > 10 files changed, 131 deletions(-)
> > delete mode 100644 bare/config/devel/autotools-base.bset
> > delete mode 100644 bare/config/devel/autotools-internal.bset
> > delete mode 100644 bare/config/devel/autotools.bset
> > delete mode 100644 rtems/config/6/rtems-autotools-base.bset
> > delete mode 100644 rtems/config/6/rtems-autotools-internal.bset
> > delete mode 100644 rtems/config/6/rtems-autotools.bset
> > delete mode 100644 rtems/config/tools/rtems-autoconf-2.69-1.cfg
> > delete mode 100644 rtems/config/tools/rtems-automake-1.12.6-1.cfg
> > diff --git a/bare/config/devel/autotools-base.bset b/bare/config/devel/autotools-base.bset
> > deleted file mode 100644
> > index 22456ed..0000000
> > --- a/bare/config/devel/autotools-base.bset
> > +++ /dev/null
> > @@ -1,9 +0,0 @@
> > -# Build set for autoconf, automake, and libtools.
> > -%define release 1
> > -devel/autoconf-2.69-1
> > -devel/automake-1.12.6-1
> > -devel/libtool-2.4.2-1
> > diff --git a/bare/config/devel/autotools-internal.bset b/bare/config/devel/autotools-internal.bset
> > index bad3890..0000000
> > --- a/bare/config/devel/autotools-internal.bset
> > +++ /dev/null
> > @@ -1,13 +0,0 @@
> > -# Tools Set for Internal Autotools Stable
> > -# Do not use via the command line.
> > -%define _internal_autotools yes
> > -%define _disable_collecting yes
> > -%define _disable_packaging yes
> > -%define _disable_reporting yes
> > -%define _disable_installing yes
> > -%include devel/autotools-base.bset
> > diff --git a/bare/config/devel/autotools.bset b/bare/config/devel/autotools.bset
> > index 5fcafa4..0000000
> > --- a/bare/config/devel/autotools.bset
> > +++ /dev/null
> > @@ -1,14 +0,0 @@
> > -%define release 1
> > -# A magic internal path that would break if changes in the defaults.mc
> > -# macro file are made.
> > -%define _internal_autotools_path %{_tmppath}/sb-%{_uid}/${SB_PREFIX_CLEAN}
> > -devel/autotools-internal.bset
> > -devel/autotools-base.bset
> > diff --git a/rtems/config/6/rtems-autotools-base.bset b/rtems/config/6/rtems-autotools-base.bset
> > index c6819c1..0000000
> > --- a/rtems/config/6/rtems-autotools-base.bset
> > +++ /dev/null
> > @@ -1,9 +0,0 @@
> > -%define release 1
> > -%define rtems_arch none
> > -%include 6/rtems-base.bset
> > -package: rtems-%{rtems_version}-autotools-%{_host}-%{release}
> > -tools/rtems-autoconf-2.69-1
> > -tools/rtems-automake-1.12.6-1
> > diff --git a/rtems/config/6/rtems-autotools-internal.bset b/rtems/config/6/rtems-autotools-internal.bset
> > index 19d2f19..0000000
> > --- a/rtems/config/6/rtems-autotools-internal.bset
> > +++ /dev/null
> > @@ -1,11 +0,0 @@
> > -%include 6/rtems-autotools-base.bset
> > diff --git a/rtems/config/6/rtems-autotools.bset b/rtems/config/6/rtems-autotools.bset
> > index e57d25d..0000000
> > --- a/rtems/config/6/rtems-autotools.bset
> > +++ /dev/null
> > @@ -1,25 +0,0 @@
> > -# Autoconf and automake are not relocatable and cannot be cross-compiled.
> > -# RTEMS uses autoconf and automake and building RTEMS in the RSB requires
> > -# bootstrapping and this requires a current autoconf and automake. The RSB
> > -# provides to support by:
> > -# 1. Building and installing autoconf and automake with a prefix to a
> > -# temporary internal path.
> > -# 2. Using the temporary internal build, build and install another copy
> > -# using the final prefix location.
> > -# Disable emailing reports of this building for RTEMS.
> > -%define mail_disable
> > -6/rtems-autotools-internal
> > -6/rtems-autotools-base
> > diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
> > index 1b60066..0c07b08 100644
> > --- a/rtems/config/6/rtems-default.bset
> > +++ b/rtems/config/6/rtems-default.bset
> > @@ -3,8 +3,6 @@
> > -6/rtems-autotools
> > # Build gdb first to raise the Python install error as early as possible.
> > # GDB needs expat so it needs to be built before.
> > diff --git a/rtems/config/6/rtems-microblaze.bset b/rtems/config/6/rtems-microblaze.bset
> > index 4b12899..3eb7a89 100644
> > --- a/rtems/config/6/rtems-microblaze.bset
> > +++ b/rtems/config/6/rtems-microblaze.bset
> > @@ -6,8 +6,6 @@
> > -6/rtems-autotools
> > devel/dtc-1.6.0-1
> > diff --git a/rtems/config/tools/rtems-autoconf-2.69-1.cfg b/rtems/config/tools/rtems-autoconf-2.69-1.cfg
> > index 71ef4ed..0000000
> > --- a/rtems/config/tools/rtems-autoconf-2.69-1.cfg
> > +++ /dev/null
> > @@ -1,23 +0,0 @@
> > -# Autoconf 2.69.
> > -%if %{rtems_arch} == none
> > - %define _target %{_host}
> > -%endif
> > -%include %{_configdir}/checks.cfg
> > -%include %{_configdir}/base.cfg
> > -%include %{_configdir}/versions.cfg
> > -%define rtems_autoconf_version 2.69
> > -# Check the version of autoconf in the path.
> > -%if %{__autoconf_ver} < %{rtems_autoconf_version}
> > - # Tools configuration.
> > - %include %{_configdir}/devel/autoconf-2.69-1.cfg
> > -%endif
> > diff --git a/rtems/config/tools/rtems-automake-1.12.6-1.cfg b/rtems/config/tools/rtems-automake-1.12.6-1.cfg
> > index f844013..0000000
> > --- a/rtems/config/tools/rtems-automake-1.12.6-1.cfg
> > +++ /dev/null
> > @@ -1,23 +0,0 @@
> > -# Automake 1.12.6
> > -%endif
> > -%define rtems_automake_version 1.12.6
> > -# Check the version of automake in the path.
> > -%if %{__automake_ver} < %{rtems_automake_version}
> > - %include %{_configdir}/devel/automake-1.12.6-1.cfg
> > -%endif
> > 1.8.3.1
> > devel mailing list
> > devel at rtems.org
