Building rtems-kernel with RSB
Ryan Long
ryan.long at oarcorp.com
Thu Sep 16 22:24:57 UTC 2021
Hi,
I'm trying to build rtems-kernel with the RSB. I haven't gotten it to work. I'm getting "Undefined reference to" errors for variables defined in tls.h (_TLS_Data_size, _TLS_Data_begin, etc.). I noticed that they are being defined in linkcmds.base in my bsp-install directory. The current command I'm using is
../source-builder/sb-set-builder \
--prefix=/home/rlong/rtems-work/bsp-install/arm-rtems6 \
-rtems-bsp=arm/xilinx_zynq_a9_qemu \
6/rtems-kernel
I'm not sure what argument needs the location of bsp-install (if it's needed). Can anyone help me out?
Thanks,
Ryan
