RSB
Thu Sep 16 23:36:24 UTC 2021
On 16/9/21 10:59 pm, Joel Sherrill wrote:
> On Wed, Sep 15, 2021 at 7:08 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 16/9/21 1:46 am, Joel Sherrill wrote:
>>> On Tue, Sep 14, 2021 at 5:52 PM Chris Johns <chrisj at rtems.org> wrote:
>>>> On 15/9/21 4:49 am, Joel Sherrill wrote:
>>> The issue I mentioned is that the same rtems-tools- at TAG@-1.tar.bz2
>>> is used for every architecture. Perhaps rtems-tools- at ARCH@- at TAG@-1.tar.bz2.
>>> Then you can script building all architectures without renaming files.
>> That implies the tools are arch specific and they are not. The tools should be
>> tagged with the host arch details if we add anything.
> The issue is that the tarball name is wrong and the rtems-tools one rtems-tools,
> binutils, gcc/newlib, and gdb. It includes EVERYTHING that is built
> when you use 6/rtems-arm.
I am not surprised, maybe the staging changes may have effected the tar naming?
If you wanted to select a parent which parent would be selected?
The current design packages at the config file level it gives you the various
pieces as a single block so you can packages them. A single tarball for the top
level would make it hard for someone to use to make packages that can be deployed.
For tools the name of the tarball needs to match the contents and it is native.
The fact each arch bset builds the same thing is a side effect of the packaging
being used. Adding the arch might create the impression each arch tools package
has to be kept separate.
> The automake tarball has automake and autoconf
I am not sure why this is happening. Maybe 2 tarballs should be created. This
stuff is a little more complicated because of the internal build stage. Autoconf
and automake cannot be cleanly relocated so in installers I have created in the
past I had the installer build the packages using the install prefix.
> The rtems-tools tarball has everything I listed above. Beyond
> rtems-tools, binutils,
> gcc/newlib, and gdb, I suppose it also includes sis or dtc on some
> architectures.
Do you want the RSB to generate user accessible tar files that need no further
touching?
> If it used the name from the top level bset it might be ok. Then you would have
> autotools and something derived from 6/rtems-arm
Yeap.
> I can send you lists of what is in each tarball if you like.
No need, I have an OK idea of what is contained in the packages
