[PATCH 1/5] score: SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP
Sebastian Huber
Fri Sep 17 07:02:55 UTC 2021
Rename SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP in
SCHEDULER_DEFAULT_SMP_OPERATIONS. Add a Doxygen comment.
cpukit/include/rtems/score/scheduler.h | 15 +++++++++++++--
cpukit/include/rtems/score/schedulercbs.h | 2 +-
cpukit/include/rtems/score/scheduleredf.h | 2 +-
cpukit/include/rtems/score/schedulerpriority.h | 2 +-
cpukit/include/rtems/score/schedulersimple.h | 2 +-
5 files changed, 17 insertions(+), 6 deletions(-)
diff --git a/cpukit/include/rtems/score/scheduler.h b/cpukit/include/rtems/score/scheduler.h
index da1e030ab8..25b6723efd 100644
--- a/cpukit/include/rtems/score/scheduler.h
+++ b/cpukit/include/rtems/score/scheduler.h
@@ -458,8 +458,19 @@ Priority_Control _Scheduler_default_Unmap_priority(
Scheduler_Node *node,
struct Per_CPU_Control *cpu
+#endif
- #define SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
+ * @brief This define provides a set of default implementations for
+ * SMP-specific scheduler operations.
+ * The default implementations are intended for uniprocessor schedulers. SMP
+ * schedulers shall implement the operations properly.
+ * If SMP support is disabled, the define evaluates to nothing.
+#if defined(RTEMS_SMP)
+ #define SCHEDULER_DEFAULT_SMP_OPERATIONS \
_Scheduler_default_Ask_for_help, \
_Scheduler_default_Reconsider_help_request, \
_Scheduler_default_Withdraw_node, \
@@ -468,7 +479,7 @@ Priority_Control _Scheduler_default_Unmap_priority(
NULL, \
NULL,
#else
#endif
diff --git a/cpukit/include/rtems/score/schedulercbs.h b/cpukit/include/rtems/score/schedulercbs.h
index e321923c11..396dfc17be 100644
--- a/cpukit/include/rtems/score/schedulercbs.h
+++ b/cpukit/include/rtems/score/schedulercbs.h
@@ -62,7 +62,7 @@ extern "C" {
_Scheduler_EDF_Update_priority, /* update priority entry point */ \
_Scheduler_EDF_Map_priority, /* map priority entry point */ \
_Scheduler_EDF_Unmap_priority, /* unmap priority entry point */ \
- SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
+ SCHEDULER_DEFAULT_SMP_OPERATIONS \
_Scheduler_CBS_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Node_destroy, /* node destroy entry point */ \
_Scheduler_CBS_Release_job, /* new period of task */ \
diff --git a/cpukit/include/rtems/score/scheduleredf.h b/cpukit/include/rtems/score/scheduleredf.h
index 065b511a14..54b1cd71bc 100644
--- a/cpukit/include/rtems/score/scheduleredf.h
+++ b/cpukit/include/rtems/score/scheduleredf.h
@@ -61,7 +61,7 @@ extern "C" {
_Scheduler_EDF_Node_initialize, /* node initialize entry point */ \
_Scheduler_EDF_Release_job, /* new period of task */ \
diff --git a/cpukit/include/rtems/score/schedulerpriority.h b/cpukit/include/rtems/score/schedulerpriority.h
index 66b976ef8f..45a312ffaf 100644
--- a/cpukit/include/rtems/score/schedulerpriority.h
+++ b/cpukit/include/rtems/score/schedulerpriority.h
@@ -52,7 +52,7 @@ extern "C" {
_Scheduler_priority_Update_priority, /* update priority entry point */ \
_Scheduler_default_Map_priority, /* map priority entry point */ \
_Scheduler_default_Unmap_priority, /* unmap priority entry point */ \
_Scheduler_priority_Node_initialize, /* node initialize entry point */ \
_Scheduler_default_Release_job, /* new period of task */ \
diff --git a/cpukit/include/rtems/score/schedulersimple.h b/cpukit/include/rtems/score/schedulersimple.h
index e201890f21..155027f3d3 100644
--- a/cpukit/include/rtems/score/schedulersimple.h
+++ b/cpukit/include/rtems/score/schedulersimple.h
@@ -51,7 +51,7 @@ extern "C" {
_Scheduler_simple_Update_priority, /* update priority entry point */ \
_Scheduler_default_Node_initialize, /* node initialize entry point */ \
2.31.1
