[PATCH v4] improve the format of error reporting on i386
Gedare Bloom
gedare at rtems.org
Mon Sep 20 17:53:27 UTC 2021
On Mon, Sep 13, 2021 at 5:44 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Sep 12, 2021 at 7:02 PM zack leung <zakthertemsdev at gmail.com> wrote:
> > Thread id is now a Hex value.
> > Updates #4203
> > cpukit/score/cpu/i386/cpu.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/cpukit/score/cpu/i386/cpu.c b/cpukit/score/cpu/i386/cpu.c
> > index 77b7a7161c..06af57418d 100644
> > --- a/cpukit/score/cpu/i386/cpu.c
> > +++ b/cpukit/score/cpu/i386/cpu.c
> > @@ -215,7 +215,7 @@ void _CPU_Exception_frame_print (const
> > CPU_Exception_frame *ctx)
> > unsigned int faultAddr = 0;
> > printk("----------------------------------------------------------\n");
> > - printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
> > PRId32 "\n",
> > + printk("Exception %" PRIu32 " caught at PC %" PRIx32 " by thread %"
> > PRIx32 "\n",
> PC and ID should use .... PC 0x%08" PRIx32.
> Prefixing with 0x to indicate that the number is hexadecimal. Printing
> it with leading zero's and 8 digits wide helps since the address and
> thread id are 32-bit (8 nibbles). A thread id is usually printed like
> 0x0a010004
Zack ^
> Does this patch have all your other changes? I've slept since seeing
> this time and thought there were changes..
> --joel
> > ctx->idtIndex,
> > ctx->eip,
> > _Thread_Executing->Object.id);
> > 2.33.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
