[PATCH v1 4/5] bsps/gicv2: Allow BSPs to define IRQ attributes
Kinsey Moore kinsey.moore at oarcorp.com
Mon Sep 20 21:38:28 UTC 2021
ARM's GICv2 is configurable and its attributes vary between
implementations including omission of specific interrupts. This allows
BSPs to accomodate those varying implementations with customized
attribute sets.
 .../shared/dev/irq/arm-gicv2-get-attributes.c | 77 +++++++++++++++++++
 bsps/shared/dev/irq/arm-gicv2-zynqmp.c        | 76 ++++++++++++++++++
 bsps/shared/dev/irq/arm-gicv2.c               | 61 +++++++--------
 spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml |  1 +
 .../altera-cyclone-v/bspalteracyclonev.yml    |  1 +
 spec/build/bsps/arm/imx/bspimx.yml            |  1 +
 .../arm/realview-pbx-a9/bsprealviewpbxa9.yml  |  1 +
 spec/build/bsps/arm/xen/bspxen.yml            |  1 +
 spec/build/bsps/arm/xilinx-zynq/obj.yml       |  1 +
 .../arm/xilinx-zynqmp/bspxilinxzynqmp.yml     |  1 +
 10 files changed, 187 insertions(+), 34 deletions(-)
 create mode 100644 bsps/shared/dev/irq/arm-gicv2-get-attributes.c
 create mode 100644 bsps/shared/dev/irq/arm-gicv2-zynqmp.c
diff --git a/bsps/shared/dev/irq/arm-gicv2-get-attributes.c b/bsps/shared/dev/irq/arm-gicv2-get-attributes.c
new file mode 100644
index 0000000000..62aa504678
--- /dev/null
+++ b/bsps/shared/dev/irq/arm-gicv2-get-attributes.c
@@ -0,0 +1,77 @@
+ * @file
+ * @ingroup RTEMSBSPsShared
+ * @brief This source file contains the interrupt get attribute implementation.
+ * Copyright (c) 2013, 2021 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <info at embedded-brains.de>
+ * are met:
+#include <dev/irq/arm-gic.h>
+#include <bsp/irq-generic.h>
+rtems_status_code bsp_interrupt_get_attributes(
+  rtems_vector_number         vector,
+  rtems_interrupt_attributes *attributes
+  attributes->is_maskable = true;
+  attributes->maybe_enable = true;
+  attributes->maybe_disable = true;
+  attributes->can_raise = true;
+  if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
+     * It is implementation-defined whether implemented SGIs are permanently
+     * enabled, or can be enabled and disabled by writes to GICD_ISENABLER0 and
+     * GICD_ICENABLER0.
+    attributes->can_raise_on = true;
+    attributes->cleared_by_acknowledge = true;
+    attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
+  } else {
+    attributes->can_disable = true;
+    attributes->can_clear = true;
+    attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
+    if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
+      /* SPI */
+      attributes->can_get_affinity = true;
+      attributes->can_set_affinity = true;
+  return RTEMS_SUCCESSFUL;
diff --git a/bsps/shared/dev/irq/arm-gicv2-zynqmp.c b/bsps/shared/dev/irq/arm-gicv2-zynqmp.c
index 0000000000..ee4479155a
--- /dev/null
+++ b/bsps/shared/dev/irq/arm-gicv2-zynqmp.c
@@ -0,0 +1,76 @@
+ * @file
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+  } else {
+     * Interrupt 67 affinity value presents as unimplemented in the
+     * configuration of the GICv2 instance used in ZynqMP CPUs.
+    if ( vector > ARM_GIC_IRQ_PPI_LAST && vector != 67 ) {
+      /* SPI */
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index 9c47a4d47b..b7898e2e97 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -64,40 +64,6 @@ void bsp_interrupt_dispatch(void)
-rtems_status_code bsp_interrupt_get_attributes(
-  rtems_vector_number         vector,
-  rtems_interrupt_attributes *attributes
-  attributes->is_maskable = true;
-  attributes->maybe_enable = true;
-  attributes->maybe_disable = true;
-  attributes->can_raise = true;
-  if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
-     * It is implementation-defined whether implemented SGIs are permanently
-     * enabled, or can be enabled and disabled by writes to GICD_ISENABLER0 and
-     * GICD_ICENABLER0.
-    attributes->can_raise_on = true;
-    attributes->cleared_by_acknowledge = true;
-    attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
-  } else {
-    attributes->can_disable = true;
-    attributes->can_clear = true;
-    attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
-    if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
-      /* SPI */
-      attributes->can_get_affinity = true;
-      attributes->can_set_affinity = true;
-  return RTEMS_SUCCESSFUL;
 rtems_status_code bsp_interrupt_is_pending(
   bool               *pending
@@ -348,11 +314,24 @@ rtems_status_code bsp_interrupt_set_affinity(
   volatile gic_dist *dist = ARM_GIC_DIST;
   uint8_t targets = (uint8_t) _Processor_mask_To_uint32_t(affinity, 0);
+  rtems_interrupt_attributes attr;
+  rtems_status_code sc;
+  memset( &attr, 0, sizeof( attr ) );
+  sc = bsp_interrupt_get_attributes( vector, &attr );
+  if ( sc ) {
+    return sc;
   if ( vector <= ARM_GIC_IRQ_PPI_LAST ) {
     return RTEMS_UNSATISFIED;
+  if ( attr.can_set_affinity == 0 ) {
+    return RTEMS_UNSATISFIED;
   gic_id_set_targets(dist, vector, targets);
@@ -364,12 +343,26 @@ rtems_status_code bsp_interrupt_get_affinity(
   uint8_t targets;
+  if ( sc ) {
+    return sc;
   targets = gic_id_get_targets(dist, vector);
+  if ( attr.can_get_affinity == 0 ) {
   _Processor_mask_From_uint32_t(affinity, targets, 0);
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
index d8286bec35..4f6b9c44d8 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
@@ -28,6 +28,7 @@ source:
 - bsps/shared/dev/clock/arm-generic-timer.c
 - bsps/shared/dev/getentropy/getentropy-cpucounter.c
 - bsps/shared/dev/irq/arm-gicv2.c
+- bsps/shared/dev/irq/arm-gicv2-zynqmp.c
 - bsps/shared/dev/serial/console-termios-init.c
 - bsps/shared/dev/serial/console-termios.c
 - bsps/shared/irq/irq-default-handler.c
diff --git a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
index a9f3f7dabf..99117573de 100644
--- a/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
+++ b/spec/build/bsps/arm/altera-cyclone-v/bspalteracyclonev.yml
@@ -132,6 +132,7 @@ source:
 - bsps/shared/dev/btimer/btimer-stub.c
+- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
 - bsps/shared/dev/rtc/rtc-support.c
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 14719745f0..79d09a3eb4 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -100,6 +100,7 @@ source:
 - bsps/shared/start/bsp-fdt.c
diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
index 2824081420..df86f8029d 100644
--- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
+++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
@@ -72,6 +72,7 @@ source:
 - bsps/shared/dev/serial/getserialmouseps2.c
diff --git a/spec/build/bsps/arm/xen/bspxen.yml b/spec/build/bsps/arm/xen/bspxen.yml
index 5b9c2e8b4d..0de27abf26 100644
--- a/spec/build/bsps/arm/xen/bspxen.yml
+++ b/spec/build/bsps/arm/xen/bspxen.yml
@@ -71,6 +71,7 @@ source:
diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
index 8a11a45dd3..f896b5a064 100644
--- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
@@ -36,6 +36,7 @@ source:
 - bsps/shared/start/bspfatal-default.c
diff --git a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
index 21a21f3812..0d336cc6cf 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp/bspxilinxzynqmp.yml
@@ -94,6 +94,7 @@ source:
2.30.2
