[PATCH rtems 5 1/2] powerpc/io: Make [out/in] le and be calls conditional
chrisj at rtems.org chrisj at rtems.org
Tue Sep 21 02:47:51 UTC 2021
- These calls clash with the Linux IO header in LibBSD. Making these
  conditional here means BSPs build and the imported Linux header is
  untouched.
Updates #4245
 bsps/powerpc/include/libcpu/io.h | 8 ++++++++
 1 file changed, 8 insertions(+)
diff --git a/bsps/powerpc/include/libcpu/io.h b/bsps/powerpc/include/libcpu/io.h
index 521c97801d..c4e529f4d5 100644
--- a/bsps/powerpc/include/libcpu/io.h
+++ b/bsps/powerpc/include/libcpu/io.h
@@ -107,6 +107,7 @@ static inline void out_be16(volatile uint16_t *addr, uint16_t val)
 	__asm__ __volatile__("sth%U0%X0 %1,%0; eieio" : "=m" (*addr) : "r" (val));
+#ifndef in_le32
 static inline uint32_t in_le32(const volatile uint32_t *addr)
 	uint32_t ret;
@@ -115,7 +116,9 @@ static inline uint32_t in_le32(const volatile uint32_t *addr)
 			     "r" (addr), "m" (*addr));
 	return ret;
+#endif
+#ifndef in_be32
 static inline uint32_t in_be32(const volatile uint32_t *addr)
 	uint32_t ret;
@@ -123,17 +126,22 @@ static inline uint32_t in_be32(const volatile uint32_t *addr)
 	__asm__ __volatile__("lwz%U1%X1 %0,%1; eieio" : "=r" (ret) : "m" (*addr));
 	return ret;
+#endif
+#ifndef out_le32
 static inline void out_le32(volatile uint32_t *addr, uint32_t val)
 	__asm__ __volatile__("stwbrx %1,0,%2; eieio" : "=m" (*addr) :
 			     "r" (val), "r" (addr));
+#endif
+#ifndef out_be32
 static inline void out_be32(volatile uint32_t *addr, uint32_t val)
 	__asm__ __volatile__("stw%U0%X0 %1,%0; eieio" : "=m" (*addr) : "r" (val));
+#endif
 #endif /* ASM */
 #endif /* _LIBCPU_IO_H */
2.24.1
