[PATCH rtems-tools 2/3] tester/wait: Add a wait directive to the tester
chrisj at rtems.org
chrisj at rtems.org
Tue Sep 21 07:42:02 UTC 2021
- Lets you test with stand alone TFTP or other services
tester/rt/config.py | 27 +++++-
tester/rt/wait.py | 154 ++++++++++++++++++++++++++++++++++
tester/rtems/testing/wait.cfg | 54 ++++++++++++
3 files changed, 233 insertions(+), 2 deletions(-)
create mode 100644 tester/rt/wait.py
create mode 100644 tester/rtems/testing/wait.cfg
diff --git a/tester/rt/config.py b/tester/rt/config.py
index 61e8f0d..a7b9ee3 100644
--- a/tester/rt/config.py
+++ b/tester/rt/config.py
@@ -52,6 +52,7 @@ import tester.rt.console
import tester.rt.exe
import tester.rt.gdb
import tester.rt.tftp
+import tester.rt.wait
timeout = 15
@@ -61,6 +62,7 @@ class file(config.file):
_directives = ['%execute',
'%gdb',
'%tftp',
+ '%wait',
'%console']
def __init__(self, index, total, report, name, opts,
@@ -217,8 +219,8 @@ class file(config.file):
if data[0] == 'stdio':
self.console = tester.rt.console.stdio(trace = console_trace)
elif data[0] == 'tty':
- if len(data) < 2 or len(data) >3:
- raise error.general(self._name_line_msg('no tty configuration provided'))
+ if len(data) < 2 or len(data) > 3:
+ raise error.general(self._name_line_msg('invalid tty configuration provided'))
if len(data) == 3:
settings = data[2]
else:
@@ -296,6 +298,25 @@ class file(config.file):
if self.console:
self.console.close()
+ def _dir_wait(self, data, total, index, exe, bsp_arch, bsp):
+ if len(data) != 0:
+ raise error.general('%wait has no arguments')
+ self.kill_on_end = True
+ if not self.opts.dry_run():
+ self.process = tester.rt.wait.wait(bsp_arch, bsp,
+ trace = self.exe_trace('wait'))
+ if not self.in_error:
+ if self.console:
+ self.console.open()
+ self.process.open(output_length = self._output_length,
+ console = self.capture_console,
+ timeout = (int(self.expand('%{timeout}')),
+ int(self.expand('%{max_test_period}')),
+ self._timeout,
+ self._test_too_long))
+ if self.console:
+ self.console.close()
def _directive_filter(self, results, directive, info, data):
if results[0] == 'directive':
_directive = results[1]
@@ -332,6 +353,8 @@ class file(config.file):
self._dir_gdb(ds, total, index, fexe, bsp_arch, bsp)
elif _directive == '%tftp':
self._dir_tftp(ds, total, index, fexe, bsp_arch, bsp)
+ elif _directive == '%wait':
+ self._dir_wait(ds, total, index, fexe, bsp_arch, bsp)
else:
raise error.general(self._name_line_msg('invalid directive'))
self._lock()
diff --git a/tester/rt/wait.py b/tester/rt/wait.py
new file mode 100644
index 0000000..a42e5e5
--- /dev/null
+++ b/tester/rt/wait.py
@@ -0,0 +1,154 @@
+# SPDX-License-Identifier: BSD-2-Clause
+'''Wait test target.'''
+# Copyright (C) 2013-2021 Chris Johns (chrisj at rtems.org)
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+from __future__ import print_function
+import datetime
+import os
+import threading
+import time
+class wait(object):
+ '''RTEMS Testing WAIT base.'''
+ # pylint: disable=useless-object-inheritance
+ # pylint: disable=too-many-instance-attributes
+ def __init__(self, bsp_arch, bsp, trace=False):
+ self.trace = trace
+ self.lock_trace = False
+ self.lock_locked = None
+ self.lock = threading.RLock()
+ self.bsp = bsp
+ self.bsp_arch = bsp_arch
+ self._init()
+ def _init(self):
+ self.output_length = None
+ self.console = None
+ self.server = None
+ self.timeout = None
+ self.test_too_long = None
+ self.timer = None
+ self.waiting = False
+ self.seconds = 0
+ def _lock(self, msg):
+ if self.lock_trace:
+ print('|[ LOCK:%s ]|' % (msg))
+ self.lock_locked = datetime.datetime.now()
+ self.lock.acquire()
+ def _unlock(self, msg):
+ period = datetime.datetime.now() - self.lock_locked
+ print('|] UNLOCK:%s [| : %s' % (msg, period))
+ self.lock.release()
+ def _trace(self, text):
+ if log.tracing:
+ log.trace('] wait: ' + text)
+ def _console(self, text):
+ if self.console:
+ self.console(text)
+ def _kill(self):
+ self._lock('_kill')
+ self._console('wait: kill')
+ self._unlock('_kill')
+ def _timeout(self):
+ self._kill()
+ if self.timeout is not None:
+ self.timeout()
+ def _test_too_long(self):
+ self._kill()
+ if self.test_too_long is not None:
+ self.test_too_long()
+ def _monitor(self, timeout):
+ output_length = self.output_length
+ period = timeout[0]
+ seconds = timeout[1]
+ self._console('wait: start: period=%d seconds=%d' % (period, seconds))
+ step = 0.5
+ period *= step
+ seconds *= step
+ self.waiting = True
+ while self.waiting and period > 0 and seconds > 0:
+ self._unlock('_monitor')
+ current_length = self.output_length()
+ if output_length != current_length:
+ period = timeout[0] * step
+ output_length = current_length
+ if seconds < step:
+ seconds = 0
+ else:
+ seconds -= step
+ if period < step:
+ step = period
+ period = 0
+ else:
+ period -= step
+ time.sleep(step)
+ self._lock('_monitor')
+ if self.waiting:
+ if period == 0:
+ self._timeout()
+ elif seconds == 0:
+ self._test_too_long()
+ self._console('wait: finished: period=%d seconds=%d' % (period, seconds))
+ def open(self, output_length, console, timeout):
+ '''Start to wait'''
+ # pylint: disable=too-many-arguments
+ self._lock('_open')
+ self._init()
+ self.output_length = output_length
+ self.console = console
+ self.timeout = timeout[2]
+ self.test_too_long = timeout[3]
+ self._monitor(timeout)
+ def kill(self):
+ '''Kill the test run.'''
+ self._kill()
+ def target_restart(self, started):
+ pass
+ def target_reset(self, started):
+ pass
+ def target_start(self):
+ pass
+ def target_end(self):
+ pass
diff --git a/tester/rtems/testing/wait.cfg b/tester/rtems/testing/wait.cfg
index 0000000..4eade4f
--- /dev/null
+++ b/tester/rtems/testing/wait.cfg
@@ -0,0 +1,54 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2010-2021 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# Wait
+# Use a wait command to wait the timeout period. The wait will be stopped
+# when the test finishes.
+%include %{_configdir}/base.cfg
+%include %{_configdir}/checks.cfg
+# Console.
+%include %{_configdir}/console.cfg
+# RTEMS version
+%include %{_rtdir}/rtems/version.cfg
+# Wait
+%wait
2.24.1
