[PATCH v2 3/6] cpukit/aarch64: Add Exception Manager support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Sep 23 00:16:51 UTC 2021
This adds the call and support functions necessary to add Exception
Manager support to AArch64.
.../cpu/aarch64/aarch64-exception-default.S | 81 +--------
.../cpu/aarch64/aarch64-exception-default.c | 62 +++++++
.../cpu/aarch64/aarch64-exception-interrupt.S | 165 ++++++++++++++++++
spec/build/cpukit/optexceptionmanager.yml | 4 +
4 files changed, 238 insertions(+), 74 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.S b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
index 2a4ddbcc61..ef95619fb1 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.S
@@ -203,14 +203,13 @@ curr_el_spx_sync_get_pc: /* The current PC is now in LR */
/* Store the vector */
str lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET]
mov x0, sp
- blr x1
-/* bl to CEF restore routine (doesn't restore lr) */
- bl .pop_exception_context
- ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET] /* get lr from CEF */
-/* drop space reserved for CEF and clear exclusive */
- add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
- msr spsel, #1 /* switch to thread stack */
- eret /* exception return */
+/* Not expected to return */
+ br x1
+ nop
+ nop
+ nop
+ nop
+ nop
nop
nop
nop
@@ -475,69 +474,3 @@ twiddle:
stp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
/* Done, return to exception handler */
ret
- * Apply the exception frame to the current register status, SP points to the EF
-.pop_exception_context:
-/* Pop daif and spsr */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
-/* Restore daif and spsr */
- msr DAIF, x2
- msr SPSR_EL1, x3
-/* Pop FAR and ESR */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
-/* Restore ESR and FAR */
- msr ESR_EL1, x2
- msr FAR_EL1, x3
-/* Pop fpcr and fpsr */
- ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
-/* Restore fpcr and fpsr */
- msr FPSR, x2
- msr FPCR, x3
-/* Pop VFP registers */
- ldp q0, q1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
- ldp q2, q3, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
- ldp q4, q5, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
- ldp q6, q7, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
- ldp q8, q9, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
- ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
- ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
- ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
- ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
- ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
- ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
- ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
- ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
- ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
- ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
- ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
-/* Pop x0-x29(fp) */
- ldp x2, x3, [sp, #0x10]
- ldp x4, x5, [sp, #0x20]
- ldp x6, x7, [sp, #0x30]
- ldp x8, x9, [sp, #0x40]
- ldp x10, x11, [sp, #0x50]
- ldp x12, x13, [sp, #0x60]
- ldp x14, x15, [sp, #0x70]
- ldp x16, x17, [sp, #0x80]
- ldp x18, x19, [sp, #0x90]
- ldp x20, x21, [sp, #0xa0]
- ldp x22, x23, [sp, #0xb0]
- ldp x24, x25, [sp, #0xc0]
- ldp x26, x27, [sp, #0xd0]
- ldp x28, x29, [sp, #0xe0]
-/* Pop sp and ELR */
- ldp x0, x1, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET]
-/* Restore thread SP */
- msr spsel, #1
- mov sp, x0
- msr spsel, #0
-/* Restore exception LR */
- msr ELR_EL1, x1
- ldp x0, x1, [sp, #0x00]
-/* We must clear reservations to ensure consistency with atomic operations */
- clrex
- ret
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index 2ebb3dee9f..4e7484f718 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -43,8 +43,70 @@
#include <rtems/score/cpu.h>
#include <rtems/fatal.h>
+#include <rtems/exception.h>
void _AArch64_Exception_default( CPU_Exception_frame *frame )
rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
+void Exception_Manager_Copy_CPU_Exception_frame(
+ CPU_Exception_frame *new_ef,
+ CPU_Exception_frame *old_ef
+ *new_ef = *old_ef;
+#define ESR_EC_GET(reg) ( ( reg >> 26 ) & 0x3f )
+#define ESR_ISS_GET(reg) ( reg & 0x1ffffff )
+#define WnR ( 1 << 6 )
+Exception_Class Exception_Manager_Get_class( CPU_Exception_frame *ef )
+ uint64_t EC = ESR_EC_GET( ef->register_syndrome );
+ uint64_t ISS = ESR_ISS_GET( ef->register_syndrome );
+ switch ( EC ) {
+ case 0x1: /* WFI */
+ case 0x7: /* SVE/SIMD/FP */
+ case 0xa: /* LD64B/ST64B* */
+ case 0x18: /* MSR/MRS/system instruction */
+ case 0x19: /* SVE */
+ return EXCEPTION_TRAPPED_INSTRUCTION;
+ case 0x15:
+ return EXCEPTION_SUPERVISOR;
+ case 0x21:
+ return EXCEPTION_INSTRUCTION_ABORT;
+ case 0x22:
+ return EXCEPTION_PC_ALIGNMENT;
+ case 0x25:
+ return ( ISS & WnR ) ? EXCEPTION_DATA_ABORT_WRITE : EXCEPTION_DATA_ABORT_READ;
+ case 0x26:
+ return EXCEPTION_SP_ALIGNMENT;
+ case 0x2c:
+ return EXCEPTION_FPU;
+ case 0x31:
+ return EXCEPTION_BREAKPOINT;
+ case 0x33:
+ return EXCEPTION_STEP;
+ case 0x35:
+ return EXCEPTION_WATCHPOINT;
+ case 0x3c:
+ return EXCEPTION_BREAK_INSTRUCTION;
+ /* AArch32-specific, from-EL0, etc. */
+ default:
+ return EXCEPTION_UNKNOWN;
+void Exception_Manager_Set_resume( CPU_Exception_frame *ef, void *address )
+ ef->register_pc = address;
+#define AARCH64_INSTRUCTION_SIZE 4
+void Exception_Manager_Set_resume_next_instruction( CPU_Exception_frame *ef )
+ ef->register_pc += AARCH64_INSTRUCTION_SIZE;
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
index b206f5764b..4ba05a17e7 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S
@@ -45,6 +45,8 @@
.globl _AArch64_Exception_interrupt_no_nest
.globl _AArch64_Exception_interrupt_nest
+.globl Exception_Manager_dispatch_and_resume
+.globl Exception_Manager_resume
#ifdef AARCH64_MULTILIB_ARCH_V8_ILP32
#ifdef RTEMS_SMP
@@ -324,3 +326,166 @@ Return to embedded exception vector code
pop_interrupt_context
/* Return to vector for final cleanup */
ret
+ * This function is expected to resume execution using the CPU_Exception_frame
+ * provided in x0. This function does not adhere to the AAPCS64 calling
+ * convention because all necessary state is contained within the exception
+ * frame.
+Exception_Manager_resume:
+/* Reset stack pointer */
+ mov sp, x0
+/* call CEF restore routine (doesn't restore lr) */
+ bl .pop_exception_context
+/* get lr from CEF */
+ ldr lr, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET]
+/* drop space reserved for CEF */
+ add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE
+/* switch to thread stack */
+ msr spsel, #1
+ eret
+ * This function is expected to undo dispatch disabling, perform dispatch, and
+ * resume execution using the CPU_Exception_frame provided in x0. This function
+ * does not adhere to the AAPCS64 calling convention because all necessary
+ * state is contained within the exception frame.
+Exception_Manager_dispatch_and_resume:
+/* Get per-CPU control of current processor */
+ GET_SELF_CPU_CONTROL SELF_CPU_CONTROL_GET_REG
+ mov sp, x0
+/* Check dispatch disable and perform dispatch if necessary */
+/* Load some per-CPU variables */
+ ldr w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ ldrb w1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
+ ldr w2, [SELF_CPU_CONTROL, #PER_CPU_ISR_DISPATCH_DISABLE]
+ ldr w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* Decrement levels and determine thread dispatch state */
+ eor w1, w1, w0
+ sub w0, w0, #1
+ orr w1, w1, w0
+ orr w1, w1, w2
+ sub w3, w3, #1
+/* Store thread dispatch disable and ISR nest levels */
+ str w0, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+ str w3, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+/* store should_skip_thread_dispatch in x22 */
+ mov x22, x1
+ * It is now safe to assume that the source of the exception has been resolved.
+ * Copy the exception frame to the thread stack to be compatible with thread
+ * dispatch. This may arbitrarily clobber corruptible registers since all
+ * important state is contained in the exception frame.
+ * No need to save current LR since this will never return to the caller.
+ bl .move_exception_frame_and_switch_to_thread_stack
+ * Check thread dispatch necessary, ISR dispatch disable and thread dispatch
+ * disable level.
+ cmp x22, #0
+ bne .Lno_need_thread_dispatch_resume
+ bl .AArch64_Perform_Thread_Dispatch
+.Lno_need_thread_dispatch_resume:
+ eret
+/* Assumes sp currently points to the EF on the exception stack and SPSel is 0 */
+.move_exception_frame_and_switch_to_thread_stack:
+ mov x1, sp /* Set x1 to the current exception frame */
+ msr spsel, #1 /* switch to thread stack */
+ ldr x0, [x1, #AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET] /* Get thread SP from exception frame since it may have been updated */
+ mov sp, x0
+ sub sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE /* reserve space for CEF */
+ mov x0, sp /* Set x0 to the new exception frame */
+ mov x20, lr /* Save LR */
+ bl Exception_Manager_Copy_CPU_Exception_frame /* Copy exception frame to reserved thread stack space */
+ mov lr, x20 /* Restore LR */
+ msr spsel, #0 /* switch to exception stack */
+ add sp, sp, #AARCH64_EXCEPTION_FRAME_SIZE /* release space for CEF on exception stack */
+ ret
+ * Apply the exception frame to the current register status, SP points to the EF
+.pop_exception_context:
+/* Pop daif and spsr */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET]
+/* Restore daif and spsr */
+ msr DAIF, x2
+ msr SPSR_EL1, x3
+/* Pop FAR and ESR */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET]
+/* Restore ESR and FAR */
+ msr ESR_EL1, x2
+ msr FAR_EL1, x3
+/* Pop fpcr and fpsr */
+ ldp x2, x3, [sp, #AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET]
+/* Restore fpcr and fpsr */
+ msr FPSR, x2
+ msr FPCR, x3
+/* Pop VFP registers */
+ ldp q0, q1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x000)]
+ ldp q2, q3, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x020)]
+ ldp q4, q5, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x040)]
+ ldp q6, q7, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x060)]
+ ldp q8, q9, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x080)]
+ ldp q10, q11, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0a0)]
+ ldp q12, q13, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0c0)]
+ ldp q14, q15, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x0e0)]
+ ldp q16, q17, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x100)]
+ ldp q18, q19, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x120)]
+ ldp q20, q21, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x140)]
+ ldp q22, q23, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x160)]
+ ldp q24, q25, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x180)]
+ ldp q26, q27, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1a0)]
+ ldp q28, q29, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1c0)]
+ ldp q30, q31, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET + 0x1e0)]
+/* Pop x0-x29(fp) */
+ ldp x2, x3, [sp, #0x10]
+ ldp x4, x5, [sp, #0x20]
+ ldp x6, x7, [sp, #0x30]
+ ldp x8, x9, [sp, #0x40]
+ ldp x10, x11, [sp, #0x50]
+ ldp x12, x13, [sp, #0x60]
+ ldp x14, x15, [sp, #0x70]
+ ldp x16, x17, [sp, #0x80]
+ ldp x18, x19, [sp, #0x90]
+ ldp x20, x21, [sp, #0xa0]
+ ldp x22, x23, [sp, #0xb0]
+ ldp x24, x25, [sp, #0xc0]
+ ldp x26, x27, [sp, #0xd0]
+ ldp x28, x29, [sp, #0xe0]
+/* Pop ELR, SP already popped */
+ ldr x1, [sp, #(AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET + 0x8)]
+/* Restore exception LR */
+ msr ELR_EL1, x1
+ ldp x0, x1, [sp, #0x00]
+/* We must clear reservations to ensure consistency with atomic operations */
+ clrex
+ ret
diff --git a/spec/build/cpukit/optexceptionmanager.yml b/spec/build/cpukit/optexceptionmanager.yml
index 2188e16cf1..4d4e09c86a 100644
--- a/spec/build/cpukit/optexceptionmanager.yml
+++ b/spec/build/cpukit/optexceptionmanager.yml
@@ -12,6 +12,10 @@ default-by-variant: []
description: |
Enable the Exception Manager
enabled-by:
+- aarch64/xilinx_zynqmp_ilp32_qemu
+- aarch64/xilinx_zynqmp_ilp32_zu3eg
+- aarch64/xilinx_zynqmp_lp64_qemu
+- aarch64/xilinx_zynqmp_lp64_zu3eg
links: []
type: build
2.30.2
