[PATCH v2 1/6] cpukit/aarch64: Use correct interrupt level types
Kinsey Moore kinsey.moore at oarcorp.com
Thu Sep 23 00:16:49 UTC 2021
All other architectures use uint32_t for interrupt levels and there is
no reason not to do so on AArch64.
 cpukit/score/cpu/aarch64/cpu.c                     | 4 ++--
 cpukit/score/cpu/aarch64/include/rtems/score/cpu.h | 4 ++--
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index d09403a349..b36f55ae17 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -146,7 +146,7 @@ void _CPU_Context_Initialize(
-void _CPU_ISR_Set_level( uint64_t level )
+void _CPU_ISR_Set_level( uint32_t level )
   /* Set the mask bit if interrupts are disabled */
   level = level ? AARCH64_PSTATE_I : 0;
@@ -156,7 +156,7 @@ void _CPU_ISR_Set_level( uint64_t level )
-uint64_t _CPU_ISR_Get_level( void )
+uint32_t _CPU_ISR_Get_level( void )
   uint64_t level;
diff --git a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
index 82f74193a2..ae7e2bdcba 100644
--- a/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/aarch64/include/rtems/score/cpu.h
@@ -204,9 +204,9 @@ static inline void _AARCH64_Instruction_synchronization_barrier( void )
   __asm__ volatile ( "isb" : : : "memory" );
-void _CPU_ISR_Set_level( uint64_t level );
+void _CPU_ISR_Set_level( uint32_t level );
-uint64_t _CPU_ISR_Get_level( void );
+uint32_t _CPU_ISR_Get_level( void );
 #if defined(AARCH64_DISABLE_INLINE_ISR_DISABLE_ENABLE)
 uint64_t AArch64_interrupt_disable( void );
2.30.2
