[PATCH v2 5/6] cpukit: Add signal mapping support
Kinsey Moore kinsey.moore at oarcorp.com
Thu Sep 23 00:16:53 UTC 2021
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
 cpukit/doxygen/appl-config.h               |  25 ++++-
 cpukit/include/rtems/confdefs/extensions.h |   7 ++
 cpukit/include/rtems/exception.h           |  12 +++
 cpukit/score/src/exceptionmapping.c        | 106 +++++++++++++++++++++
 spec/build/cpukit/librtemscpu.yml          |   2 +
 spec/build/cpukit/objexceptionmapping.yml  |  15 +++
 6 files changed, 166 insertions(+), 1 deletion(-)
 create mode 100644 cpukit/score/src/exceptionmapping.c
 create mode 100644 spec/build/cpukit/objexceptionmapping.yml
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index bbeb438bec..8ad3a3c70e 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -3,7 +3,7 @@
  * Copyright (C) 2019, 2021 embedded brains GmbH (http://www.embedded-brains.de)
  * Copyright (C) 2010 Gedare Bloom
- * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+ * Copyright (C) 1988, 2021 On-Line Applications Research Corporation (OAR)
  * modification, are permitted provided that the following conditions
@@ -1773,6 +1773,29 @@
 #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+/* Generated from spec:/acfg/if/exception-to-signal-mapping */
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the machine exception to
+ * POSIX signal mapping is configured during system initialization.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver is responsible for setting up a mapping from machine
+ * exceptions to POSIX signals so that applications may consume them and alter
+ * task execution as necessary.
+ * This is especially useful for applications written in Ada or C++.
+ * @endparblock
+#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
 /* Generated from spec:/acfg/if/max-drivers */
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index 83d690d50a..767c9028d1 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -93,6 +93,10 @@
   #include <rtems/stackchk.h>
 #endif
+#ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+  #include <rtems/exception.h>
+#endif
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -103,6 +107,9 @@ extern "C" {
   || defined(CONFIGURE_INITIAL_EXTENSIONS) \
   || defined(BSP_INITIAL_EXTENSION)
   const User_extensions_Table _User_extensions_Initial_extensions[] = {
+    #ifdef CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+      { .fatal = _Exception_map_signal },
+    #endif
     #ifdef _CONFIGURE_RECORD_NEED_EXTENSION
         #ifdef CONFIGURE_RECORD_EXTENSIONS_ENABLED
diff --git a/cpukit/include/rtems/exception.h b/cpukit/include/rtems/exception.h
index 89edfd02b4..547d7c42c2 100644
--- a/cpukit/include/rtems/exception.h
+++ b/cpukit/include/rtems/exception.h
@@ -159,6 +159,18 @@ void Exception_Manager_Copy_CPU_Exception_frame(
   CPU_Exception_frame *old_ef
+ * @brief Handle an exception frame for mapping signals
+ * See CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING documentation in the
+ * "RTEMS Classic API Guide".
+void _Exception_map_signal(
+  Internal_errors_Source source,
+  bool                   always_set_to_false,
+  Internal_errors_t      code
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/score/src/exceptionmapping.c b/cpukit/score/src/exceptionmapping.c
new file mode 100644
index 0000000000..a1b1146d1c
--- /dev/null
+++ b/cpukit/score/src/exceptionmapping.c
@@ -0,0 +1,106 @@
+ * @file
+ * @ingroup RTEMSScoreExceptionMapping
+ * @brief AArch64 machine exception to POSIX signal mapping.
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <pthread.h>
+#include <signal.h>
+#include <rtems/exception.h>
+ * Exception handler. Map the exception class to SIGFPE, SIGSEGV
+ * or SIGILL for Ada or other runtimes.
+  CPU_Exception_frame *ef;
+  uint32_t signal;
+  Exception_Class eClass;
+  if ( source != RTEMS_FATAL_SOURCE_EXCEPTION ) {
+    return;
+  ef = (rtems_exception_frame *) code;
+  eClass = Exception_Manager_Get_class( ef );
+  switch ( eClass ) {
+    /* Don't handle exceptions other handlers are likely to be interested in */
+    case EXCEPTION_SUPERVISOR:
+    case EXCEPTION_TRAPPED_INSTRUCTION:
+    case EXCEPTION_BREAKPOINT:
+    case EXCEPTION_BREAK_INSTRUCTION:
+    case EXCEPTION_STEP:
+    case EXCEPTION_WATCHPOINT:
+    /* SP alignment can't be handled via signals alone */
+    case EXCEPTION_SP_ALIGNMENT:
+      return;
+    case EXCEPTION_FPU:
+    case EXCEPTION_TAGGED_OVERFLOW:
+    case EXCEPTION_DIV_ZERO:
+      signal = SIGFPE;
+      break;
+    case EXCEPTION_DATA_ABORT_READ:
+    case EXCEPTION_DATA_ABORT_WRITE:
+    case EXCEPTION_DATA_ABORT_UNSPECIFIED:
+    case EXCEPTION_INSTRUCTION_ABORT:
+    case EXCEPTION_MMU_UNSPECIFIED:
+    case EXCEPTION_ACCESS_ALIGNMENT:
+      signal = SIGSEGV;
+      break;
+    default:
+       * Covers unknown, PC alignment, illegal execution state, and any new
+       * exception classes that get added.
+      signal = SIGILL;
+      break;
+  /* Disable thread dispatch */
+  Exception_Manager_disable_thread_dispatch();
+  /* Send the signal. The handler will run during thread dispatch. */
+  pthread_kill( pthread_self(), signal );
+  /* Perform dispatch and resume execution */
+  Exception_Manager_dispatch_and_resume( ef );
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 6f8d223f1e..5847bdecbf 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -496,6 +496,8 @@ links:
   uid: objdl
 - role: build-dependency
   uid: objdrvmgr
+- role: build-dependency
+  uid: objexceptionmapping
   uid: objgnat
diff --git a/spec/build/cpukit/objexceptionmapping.yml b/spec/build/cpukit/objexceptionmapping.yml
index 0000000000..028cc237bd
--- /dev/null
+++ b/spec/build/cpukit/objexceptionmapping.yml
@@ -0,0 +1,15 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- RTEMS_EXCEPTION_MANAGER
+includes: []
+install: []
+links: []
+source:
+- cpukit/score/src/exceptionmapping.c
+type: build
2.30.2
