[PATCH rtems-docs] user/testing: Add the %wait directive
chrisj at rtems.org chrisj at rtems.org
Thu Sep 23 05:04:18 UTC 2021
 user/testing/configuration.rst | 84 +++++++++++++++++++++++++++++++---
 user/testing/tftp.rst          | 12 +++--
 2 files changed, 86 insertions(+), 10 deletions(-)
diff --git a/user/testing/configuration.rst b/user/testing/configuration.rst
index 9c65506..4d67482 100644
--- a/user/testing/configuration.rst
+++ b/user/testing/configuration.rst
@@ -1,6 +1,6 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018 Chris Johns <chrisj at rtems.org>
+.. Copyright (C) 2018,2021 Chris Johns <chrisj at rtems.org>
 Tester Configuration
@@ -226,9 +226,10 @@ supported directives are:
 - ``%execute``
 - ``%gdb``
 - ``%tftp``
+- ``%wait``
-.. _tester-config-console:
 .. index:: Console, %console
+.. _tester-config-console:
 Console
@@ -278,10 +279,12 @@ configuration script. If the ``%{console_stdio}`` is defined the console will
 be ``stdio`` else the console will be the BSP console or ``%{bsp_tty_dev}``.
 Telnet can be combined with the ``ser2net`` daemon to remotely access a
-target's physical serial UART interface.
+target's physical serial UART interface. The syntax is ``host:port``::
+  %define bsp_tty_dev      1.2.3.4:8989
-.. _tester-config-execute:
 .. index:: Execute, %execute
+.. _tester-config-execute:
 Execute
@@ -297,8 +300,8 @@ An example is::
   %execute %{run_cmd} %{run_opts} %{test_executable} %{test_executable_opts}
-.. _tester-config-gdb:
 .. index:: GDB, %gdb
+.. _tester-config-gdb:
 GDB
@@ -313,8 +316,8 @@ An example is::
   %gdb %{gdb_cmd} %{test_executable} %{gdb_script}
-.. _tester-config-tftp:
 .. index:: TFTP, %tftp
+.. _tester-config-tftp:
 TFTP
@@ -328,3 +331,72 @@ board running the test.
 An example is::
   %tftp %{test_executable} %{tftp_port}
+The RTEMS Tester contains a TFTP server so an external TFTP is not
+needed. It is recommended a TFTP Proxy is set up to handle the TFTP
+sessions for your network. The internal TFTP server ignores the
+requrest file and serves the next executable. If the target requires
+the executable ne in a specific format provide a script via the
+``target_pretest_command`` option in your user configuration file.
+The RTEMS Tools provides a TFTP protocol proxy server. It takes a list
+of MAC addresses and proxies TFTP sessions for that MAC address to
+another IP address and port. A proxy provides the following benefits:
+1. The TFTP proxy server is the only software required to run as root
+2. All hardware targets can be configured to serve from a single
+   machine and the proxy can distribute the sessions out to developer
+   machines
+3. There is no need to provide a globally writable file system a
+   central TFTP server acceses
+If you have a central TFTP server refer to the ``%wait`` directive.
+.. index:: Wait, %wait
+.. _tester-config-wait:
+Wait
+The ``%wait`` directive waits the timeout period for a test to
+complete. The directive monitors the console output and resets the
+timeout timer if console output is seen. If the test runs for too long
+while outputing data an error is reported.
+The wait directive can be used in systems where there is an external
+mechanism being used to send the executable to the target hardware.
+An example is::
+  %wait
+Wait has no options. The timeouts are controlled in other ways.
+If you have an external system wide TFTP server with global access
+wait can used by providing a `` script that places the file in the
+location the TFTP server can see. This is done as the test start so if
+networking loading there is normally enough time to get the executable
+image in place before the transfer starts. The MVME2700
+(``powerpc/mvme2307``) is a BSP that supports the ``%wait`` directive.
+The following is an example user configuration file (see
+``--user-config``)::
+  # MVME2700 (mvme2307)
+  [mvme2307]
+  bsp_tty_dev            = 1.2.3.4:5678
+  target_pretest_command = mk-mvme2307-img @EXE@ /tftp/cjohns/rtems.img
+  target_exe_filter      = /\.exe/.exe.img/
+  target_on_command      = pw-ctl 1.2.3.4 toggle-on 3 1
+  target_off_command     = pw-ctl 1.2.3.4 off 3
+  target_reset_command   = pw-ctl 1.2.3.4 toggle-on 3 1
+The script ``mk-mvme2307-img`` converts the RTEMS ELF executable into
+the PowerPC prep bootloader format and copies the file to the TFTP
+server's network wide location. The MVME2700 is configured to request
+``rtems.img`` from this location. The command ``pw-ctl`` is a command
+to control the power to the board.
diff --git a/user/testing/tftp.rst b/user/testing/tftp.rst
index ade8f9a..4cb16ef 100644
--- a/user/testing/tftp.rst
+++ b/user/testing/tftp.rst
@@ -10,10 +10,14 @@ TFTP and U-Boot
 .. index:: TFTP, U-Boot, Testing
 TFTP and U-Boot provides a simple way to test RTEMS on a network capable
-target. The RTEMS Tester starts a TFTP server for each test and the target's
-boot monitor, in this case U-Boot request a file, any file, which the TFTP
-server supplies. U-Boot loads the executable and boots it using a standard
-U-Boot script.
+target. The RTEMS Tester starts a TFTP server session for each test and the
+target's boot monitor, in this case U-Boot request a file, any file, which the
+TFTP server supplies. U-Boot loads the executable and boots it using a
+standard U-Boot script.
+The RTEMS Tester contains a TFTP server so no external TFTP server or
+configuration is required. If you have an external TFTP server and wish to use
+that resource the :ref:`tester-config-wait` directive can be used.
 .. _fig-tester-tftp-u-boot:
2.24.1
