[PATCH rtems-tools v2 5/7] TraceWriterQEMU.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Thu Sep 23 21:27:00 UTC 2021
tester/covoar/TraceWriterQEMU.cc | 47 +++++++++++++++++++++++++---------------
1 file changed, 29 insertions(+), 18 deletions(-)
diff --git a/tester/covoar/TraceWriterQEMU.cc b/tester/covoar/TraceWriterQEMU.cc
index d14260f..1f0e719 100644
--- a/tester/covoar/TraceWriterQEMU.cc
+++ b/tester/covoar/TraceWriterQEMU.cc
@@ -60,9 +60,9 @@ namespace Trace {
bool TraceWriterQEMU::writeFile(
- const std::string& file,
- Trace::TraceReaderBase *log,
- bool verbose
+ const std::string& file,
+ Trace::TraceReaderBase* log,
+ bool verbose
struct trace_header header;
@@ -96,13 +96,13 @@ namespace Trace {
// Write the Header to the file
- strncpy( header.magic, QEMU_TRACE_MAGIC, sizeof(header.magic) );
- header.version = QEMU_TRACE_VERSION;
- header.kind = QEMU_TRACE_KIND_RAW; // XXX ??
+ strncpy( header.magic, QEMU_TRACE_MAGIC, sizeof( header.magic ) );
+ header.version = QEMU_TRACE_VERSION;
+ header.kind = QEMU_TRACE_KIND_RAW; // XXX ??
header.sizeof_target_pc = 32;
- header.big_endian = false;
- header.machine[0] = 0; // XXX ??
- header.machine[1] = 0; // XXX ??
+ header.big_endian = false;
+ header.machine[0] = 0; // XXX ??
+ header.machine[1] = 0; // XXX ??
traceFile.write( (char *) &header, sizeof( trace_header ) );
if ( traceFile.fail() ) {
@@ -110,35 +110,42 @@ namespace Trace {
return false;
- if (verbose)
+ if ( verbose ) {
std::cerr << "magic = " << QEMU_TRACE_MAGIC << std::endl
<< "version = " << header.version << std::endl
<< "kind = " << header.kind << std::endl
<< "sizeof_target_pc = " << header.sizeof_target_pc << std::endl
<< "big_endian = " << header.big_endian << std::endl
- << std::hex << std::setfill('0')
- << "machine = " << std::setw(2) << header.machine[0]
+ << std::hex << std::setfill( '0' )
+ << "machine = " << std::setw( 2 ) << header.machine[0]
<< ':' << header.machine[1]
- << std::dec << std::setfill(' ')
+ << std::dec << std::setfill( ' ' )
<< std::endl;
// Loop through log and write each entry.
<<<<<<< HEAD
+<<<<<<< HEAD
for (const auto & itr : log->Trace.set) {
struct trace_entry32 entry;
for ( const auto& itr : log->Trace.set ) {
>>>>>>> cdf7855... TraceWriterQEMU.cc: Fix
+ for ( const auto & itr : log->Trace.set ) {
+ struct trace_entry32 entry;
+>>>>>>> 4d16457... TraceWriterQEMU.cc: Fix formatting
entry._pad[0] = 0;
entry.pc = itr.lowAddress;
entry.size = itr.length;
entry.op = TRACE_OP_BLOCK;
- switch (itr.exitReason) {
+ switch ( itr.exitReason ) {
case TraceList::EXIT_REASON_BRANCH_TAKEN:
entry.op |= taken;
break;
@@ -148,15 +155,19 @@ namespace Trace {
case TraceList::EXIT_REASON_OTHER:
break;
default:
- throw rld::error( "Unknown exit Reason", "TraceWriterQEMU::writeFile" );
+ throw rld::error(
+ "Unknown exit Reason",
+ "TraceWriterQEMU::writeFile"
break;
- if ( verbose )
- std::cerr << std::hex << std::setfill('0')
+ if ( verbose ) {
+ std::cerr << std::hex << std::setfill( '0' )
<< entry.pc << ' ' << entry.size << ' ' << entry.op
<< std::endl;
traceFile.write( (char *) &entry, sizeof( entry ) );
1.8.3.1
